Old 03-07-2024, 10:52 AM #1
Bedstraps's Avatar
Bedstraps Bedstraps is offline
Bedstraps is on a distinguished road
Bedstraps's Avatar
Climate Control selection Issue
When I change the climate control from defrost to face or face to defrost or any combination of selection, the selection is not completely made. It tries to change but it is kinda stuck at defrost or some combination of defrost/feet. So I think the control panel is working but the mechanical component within the HVAC system that changes the output is malfunctioning or stuck because I hear the noise of the air change upon each selection. Does anyone know where I can obtain a diagram of the system or what the part is called that changes to air direction?
Geaux Saints
Bedstraps is offline   Reply With QuoteReply With Quote
Old 03-07-2024, 05:59 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
What year and is it a Limited, SR5, or Sport Edition?
The actuator for that is called "Mode" and is most likely the issue, it is located behind the glovebox, there are other actuators back in there as well so it's important to find the correct one, once you drop the glove box out of the way you should be able to look up in there as you change the "modes" and see which one is moving or trying to move or making noise, it maybe that the arm on the actuator has slipped out of sync with the rest of the actuator and can be carefully slipped back in place or it shot and needs replacing, these actuators are not fun to swap out because of the tight space, but it is doable as a DIY job, there are plenty of writeups on the forum and probably videos on YouTube as well.
2004 Limited V8
Old 03-07-2024, 07:52 PM #3
SocalSam SocalSam is offline
SocalSam will become famous soon enough SocalSam will become famous soon enough
This. There is also an actuator on the left side of the blend box. Here is an image I found on ebay. Highlighted actuator may not be the right one.
SocalSam is offline   Reply With QuoteReply With Quote
climate , control , defrost , issue , selection
Climate control issue jeffsGT7 4th Gen T4Rs 6 02-22-2020 02:41 PM
04 Limited Climate Control issue nicheel8 4th Gen T4Rs 6 10-21-2016 05:08 PM
2006 limited climate control issue JEL 4th Gen T4Rs 4 11-17-2015 09:59 PM
Climate Control Issue smallfry 3rd gen T4Rs 1 08-01-2011 12:35 AM
Climate Control Issue After Kenwood DDX418 Install rtuck1 4th Gen T4Rs 11 05-22-2011 11:47 PM
