Old 03-02-2024, 08:15 AM #1
twa318 twa318 is offline
twa318 is on a distinguished road
Video of what a failed rear pinion bearing sounds like
Future reference for anyone who is having the same problem, here is a video I took of what it sounds like when the rear pinion bearing has failed.
https://streamable.com/i9nhjl
You can hear it best last 15 seconds of the video, it was loudest when coasting to to a stop from 25mph
Just got a remanned differential from East Coast Gear Service put in and it’s now whisper quiet.
Another ECGS success story
'99 SR5, 2007 Sport
twa318 is offline   Reply With QuoteReply With Quote
Old 03-02-2024, 10:13 AM #2
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
Interesting thanks for posting that. My 2WD makes a whirring sound at 50 - 60mph, it seems to need to warm up a little bit for it to happen. I am hoping it is a wheel bearing or maybe even the tyres as it doesn't seem to change tone whether at constant speed or on the over-run decelerating.
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
Old 03-02-2024, 08:16 PM #3
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
After I tried replacing leaky pinion seal, I overtightened the bolt and after a long trip and pulling into my drive, I hear the wrrerrchunkachinkaclinkwirrrrchunkachunkaclink.
I had the dealer do mine.. didn't have a garage at the time and cost about $2200
gaber6 is offline   Reply With QuoteReply With Quote
Old 03-04-2024, 05:45 PM #4
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
Curious, did it fail because of lack of gear oil or age? How many miles?
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 03-04-2024, 07:46 PM #5
SurferUK's Avatar
SurferUK's Avatar
Originally Posted by MikeinNH67 View Post
lack of fear oil
I'm afraid so.
Old 03-05-2024, 08:08 AM #6
frostyflammable frostyflammable is offline
frostyflammable is on a distinguished road
I am trying to figure out a similar-ish noise on my 04 4Runner, hoping its one of the bearings as it noise pretty much goes away when turning to the right and taking weight off the right side of the vehicle.
frostyflammable is offline   Reply With QuoteReply With Quote
Old 03-05-2024, 02:27 PM #7
SurferUK's Avatar
SurferUK's Avatar
Could you find a wide open area and knock it into Neutral and see if the noise remains?
Old 03-05-2024, 04:14 PM #8
Sure can, I live out in the country so empty roads for days. What am I expecting if the noise goes away while in neutral, does that mean it's something inside the trans?
Old 03-05-2024, 04:21 PM #9
SurferUK's Avatar
SurferUK's Avatar
I have a hunch if it's just as noisy in neutral it's a bearing, you've already done the test of loading up each side. In neutral I think the diff and prop shaft are still turning but not under any drag from the gearbox so if the noise is identical it seems like it wouldn't be the diff. I think so, anyway!
Old 03-05-2024, 04:34 PM #10
Awesome idea to try, will try it tonight when I get home. Thanks!
Old 03-05-2024, 05:05 PM #11
MikeinNH67's Avatar
MikeinNH67's Avatar
I'm afraid so.
LOL, good catch and reply, bad proofreading by me.
As for the later questions, a wheel bearing will generally quiet down when you turn hard in the direction of the bad side as it releases some weight off the bearing. Not 100% but can be helpful. It seems yours fits that criteria. Of course, I still replaced the wrong side on mine so it ended up with 2 new front wheel bearings.
I've only seen one diff bearing go bad and that was on my son's ranger. It leaked out all the gear oil and locked up. The pumpkin had a small rust hole in it if I remember correctly.
Mike
03 4runner Limited
Old 03-05-2024, 06:38 PM #12
SurferUK's Avatar
SurferUK's Avatar
Let us know, here's hoping it gives you a clue and it turns out to be something cheap and easy!
Old 03-05-2024, 10:29 PM #13
To update everyone... while I had to car in for an alignment at a local independent shop I trust asked them to look at the noise... after they test drove it, put it on the lift and did some diag they told me that the rear differential needs to be replaced. Apparently the noise is coming from the differential itself however they did not open it to get a close look as it was close to end of day, but he was pretty sure it needed a new diff. He quoted me $2500 including a new axle, diff and the labor to replace it however I want to do this on a budget. Reading up seems East Coast Gear Supply seems to be the one to go with so I am going to email them see what kind of price we are talking about for a new diff. Never replaced the diff, however seems take axles out, drop the driveshaft, some swearing trying to get stuck bolts out, take way too much time finding dropped tools etc. Not sure yet which way I will go, however will see what ECGS has to say.
I will start a whole new thread once I reach 15 posts to document everyhting.
Old 03-05-2024, 10:35 PM #14
I also tried throwing it in neutral while at speed and could not hear or feel any difference.
Old 03-06-2024, 04:37 AM #15
SurferUK's Avatar
SurferUK's Avatar
Have you jacked it up and tried to rock each wheel?
It does sound like a wheel bearing, if it was the diff I wouldn't expect the neutral test to make the noise stop, although I suppose it could, but at the least the tone of the noise should change as everything that part of the drive-line would be rotating freely.
What's your diff oil age and level?
failed , pinion , rear , sounds , video
Rear pinion bearing replacement kit? thebrandon 3rd gen T4Rs 5 07-08-2014 12:48 AM
pinion carrier bearing/pinion input bearing Fin Australia 0 09-28-2013 01:43 AM
Help !! Squeal from rear end. ?pinion bearing? shaw1755 3rd gen T4Rs 4 01-08-2013 09:17 PM
