Old 03-11-2024, 10:58 AM #1
joshik joshik is offline
joshik will become famous soon enough
Rear Helper Air Bags - do they limit up travel
I'm looking to install some helper air bags to increase spring rate when wheeling with a load (camp gear, some tools and family) without having to change to heavier spring rate rear springs for everyday use. I've looked around on here and most people use them for towing on road. However, I haven't found much info or discussion when using off road. If there are some threads it talks about having them at the minimum 5psi but if you have them, why would you be at 5psi? You would have them inflated to increase the spring rate for your load while off road.
My question, does anyone have experience with them limiting up travel when wheeling with a load and the bags inflated well above minimum?
I know that you cut off part of your spring isolator during the install so I guess it won't? Just wanted to get some feedback from those who wheel with them with a load.
2003 4Runner Limited 4wd V8. JBA UCA, Dobinsons MRA Front Coilovers, Dobinsons MRA Long Travel rear. Cooper AT3 XLT 285/70R17
91 Ext Cab 4x4 Yota, black with 4" front IFS trailmaster lift, 3" Downey rear springs, Downey Rubicon extended shackles, and 2" body lift. 35" BFG M/T w/ 4.56. Centerforce II clutch, Rancho 5000s all around and Rancho traction bar, K&N Air filter, Flowmaster, ARB Rear Diff Air Locker, Custom "Mad Eyes" light covers, Extended Diff Breathers, Hella Vision Plus Headlights. [SOLD]
joshik is offline   Reply With QuoteReply With Quote
Old 03-11-2024, 03:36 PM #2
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
You can get around your concern by adding a valve that'll allow you to link the airbags. I think of it like a rear swaybar disconnect. Linked bags = air is free to move from bag to bag giving you more travel when offroad. Unlinked bags = air not free to move from bag to bag, giving you more stability when towing/on road.
I followed this guide: 2007 Toyota 4Runner Air Lift. Been running my setup for 4+ years. No problems on or offroad.
'08 Silver SR5 V6 4x4: OEM+
Berty_K is offline   Reply With QuoteReply With Quote
Old 03-11-2024, 03:50 PM #3
Oh yeh, I saw that. Pretty nifty that he was able to do both single and dual air paths. My thought was how fast does the air move from one side to the other through that tiny hose. I supposed when articulating when crawling doesnt call for fast suspension cycles anyways....
bags , load , rate , road , spring
Aftermarket Spring Owners WITH Air Bags / Helper Bags WEAK_E90 5th gen T4Rs 8 03-25-2020 09:54 AM
Rear hatch weight limit MacLaddy 3rd gen T4Rs 9 09-30-2019 02:56 PM
Timbren rear over load helper davem Engines / Suspension / Wheels / Tires / Audio / Accessories 1 01-12-2017 02:24 PM
Anyone use a Daystar Leveling kit with the Firestone Rear Coil helper bags? ChaosStarter 4th Gen T4Rs 2 04-20-2015 12:33 PM
Anyone running air bags with MT Long travel springs... wfo9 5th gen T4Rs 1 03-23-2015 11:05 PM
