Old 03-12-2024, 09:46 PM #1
utmba95 utmba95 is offline
utmba95 is on a distinguished road
2003 V8 Oil leaks
Hi, I'm curious if anybody else had these leaks and has a thought on where they are coming from.
The bottom of the bell housing is fairly wet, and the rear rock guard was pretty oily. Hopefully not the rear main!
2003 V8 Oil leaks-20240312_152624-jpg
The timing belt tensioner is coated in oil. I replaced the front crank and cam seals when I did the timing chain about 20K miles ago. Since there shouldn't be oil inside the timing belt cover, I assume it's coming from higher up?
2003 V8 Oil leaks-20240312_152500-jpg
I do smell a bit of burning oil after long drives. Last time I had an oil leak it was the head cover gaskets, and I smelled burning oil every time I drove it.
utmba95 is offline   Reply With QuoteReply With Quote
Old 03-13-2024, 11:55 AM #2
Moist's Avatar
Moist Moist is offline
Moist is on a distinguished road
Moist's Avatar
Attachment 410571
Attachment 410570
Is this fresh oil?
Clean it off and then drive for a while and take note of where oil comes from. Also take note of how much it is bleeding out of there.
Moist is offline   Reply With QuoteReply With Quote
Old 03-13-2024, 04:25 PM #3
The oil on the bell housing came back in one test drive. I switched to conventional oil and will monitor it over time. It appears that I was nearly a quart low when I changed the oil. I didn't check the dipstick before, but 5qt came out, and I usually put 6qt in.
Sent from my SM-G981U using Tapatalk
Old 03-13-2024, 08:08 PM #4
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Valvoline High Mileage synthetic has "seal swell" in it to help keep seals soft and pliable, so does their semi-synthetic in the red container. I too, have an '03 V8 and no engine oil leaks and this is the oil I have used for 6-7 years now, since I've owned it.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 03-16-2024, 09:14 PM #5
Thanks for the reminder. I will try that. I've been leery of the seal swell before it was needed, but now it's time.
burning , coming , oil , rear , timing
Again with the Leaks! adkinsadam1 4th Gen T4Rs 11 03-09-2014 01:15 PM
Leaks ASUMTNEER 4th Gen T4Rs 3 06-13-2013 08:01 PM
Oil Leaks jaybirdy2k Classic T4Rs 14 04-27-2012 03:28 AM
93 leaks kroo88 Classic T4Rs 4 04-21-2011 11:58 AM
oil leaks 4ballin 3rd gen T4Rs 1 02-02-2010 11:22 PM
