Old 03-16-2024, 04:36 PM #1
jmriott jmriott is offline
jmriott is on a distinguished road
06 V8 ignition switch question
I have an intermittent no power no start issue when I turn on the key.
Cleaned battery terminals/battery tests @ 13.3 volts/checked & cleaned white fuse #25/checked grounds.
I am thinking it could be the ignition switch.
QUESTION: If I replace the switch do the keys need reprogrammed?
Thank everyone!
jmriott is offline   Reply With QuoteReply With Quote
Old 03-16-2024, 05:33 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Thank everyone!
If you replace the complete switch it will have new keys and yes the keys would have to be programed to your T4R, also the new keys obliviously will not unlock any of the doors or hatch, you would need to keep the old key/s for that.
In some vehicles the switch and keyed cylinder are separate parts.
That being said, for T4Rs I'm not sure if the switch comes in 2 pieces or just one, if 2 pieces, the switch and the keyed cylinder, then you would only need the switch and reuse the old keyed cylinder, in which case your old keys will still work everything.
2004 Limited V8
Old 03-18-2024, 12:27 PM #3
Thanks.
Car has 136k miles w/ excellent maintenance.
Checked battery voltage after sitting out overnite @ 32deg. Reading 12.24 volts.
Car starts right up.
Alternator charging@ 14.28 volts.
My wife has an 04 GX47,. 140+k miles Battery voltage after sitting in heated garage.....12.24 volts.
Preliminary conclusions: Dirty terminals/faulty ignition switch/starter going bad.
I will update this thread when I reach a solution.
Old 03-18-2024, 03:46 PM #4
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
After looking at the part online, it appears you can change the switch itself without swapping the key. I've only seen a bad switch once and the car would shut off on it's own. Plus you could make it do things by jiggling the keys. I've seen more issues with intermittent starters and neutral safety switches. Have you tried starting it in neutral when it happens?
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
#25/checked , cleaned , ignition , question , switch
Ignition Switch Going Bad? StockyStock 3rd gen T4Rs 9 10-22-2023 02:25 PM
LED Bar switch with ignition on only D's Trail Engines / Suspension / Wheels / Tires / Audio / Accessories 2 01-13-2016 12:05 AM
Ignition switch Takuanda07 3rd gen T4Rs 0 06-05-2015 04:22 PM
What is ruining the ignition switch? Graham 3rd gen T4Rs 22 12-31-2013 03:55 PM
ignition switch and key 4runnerman09 4th Gen T4Rs 10 10-12-2010 10:39 AM
