03-17-2021, 11:50 AM
Wheel Hub Bearing Assembly Suggestions?
Shop said my RF wheel bearing is going out and I'm wondering what you guys use for replacements? I've read that rock auto bearings are pretty dodgy. Has anyone had any experience with them? I need something that will ship to Canada. I'm just looking for the whole assembly since it's a lot of work to press bearings. Should I replace them in pairs or is just the one ok? Thanks guys.
03-17-2021, 01:22 PM
What’s your mileage?
You might want to consider replacing both in a pair
I used jersey built hubs and they worked out great
'99 SR5, 2007 Sport
03-17-2021, 02:08 PM
I installed Jersey built hubs a couple years ago, no complaints.
Be aware they take a couple weeks to build and ship.
-Rob
2006 Sport V8 4x4 4Runner | Mods: ARB Front Bumper | Warn XD9000 Winch | Custom Sliders | ECGS 4.56 Gears | Eaton Truetrac rear | JBA UCA | SuperPro LCA | Icon 2.5 Front Coilovers | MetalTech Icon 2.0 Long Travel Rear Shocks | Dobinsons Long Travel Rear Springs | Energy Suspension Front Bumps | Durobump Rear Bumps | Falken WildPeak 285/70/17 | SCS F5 wheels | Custom Roof Rack | Gobi Ladder | OrangeBoxx Molle Panels | Icom IC-2730a HAM Radio | Rigid Ditch Lights | Custom Rear Drawers | 23Zero Walkabout 62 | ARB Awning | Dual Battery System | CVJ Axles | Victory 4x4 Rear Bumper with Dual Swingouts | Front Runner Table
03-17-2021, 02:59 PM
I guess we're all assuming OP has a 4WD.
I went with the Beck/Arnley assemblies from Amazon. Did both as long as I was going to the trouble. Figure if one's going bad, the other side's not far behind. So far, so good although they've only been on for a couple of months at this point. In January, they were $95ish (USD) each...about the same at RockAuto, IIRC. Looks like they're up to $109 at Amazon, today.
2003-2022: '03 Limited V8 4x4 - Galactic Gray Mica
2022-Present: '21 Nightshade 4x4 - Magnetic Gray Metallic
03-17-2021, 08:15 PM
X2 on Beck/Arnley from Rock Auto. Replaced both a year ago and no issues.
03-17-2021, 08:34 PM
NAPA 77010691 actually Dorman 950-001 for three times the price...
1year 3 mos no problems....
03-18-2021, 12:16 AM
Don’t know if he ships north of the wall, but I’ve been running these since about 2017 I’d say so about four years and maybe 40k if I had to guess. No problems.
Wheel Bearings & Hubs Press Service *** 4x4 *** PreRunner *** | Tacoma World
03-18-2021, 09:12 AM
I used the Dorman assembly on both fronts about 60K miles ago, no issues.
2011 SR5 4wd
2004 SR5 4wd
1994 SR5 4wd (SOLD)
03-18-2021, 02:11 PM
I guess I'll just go with the Dorman ones they seem to have pretty good feedback and they're good n cheap.
03-18-2021, 02:13 PM
360k kms, yeah I think I'll replace both but tbh I'm not convinced they even need replacing yet I have been trying to hear them make noise and I don't hear anything.
03-18-2021, 02:14 PM
I don't think we get 2wd 4runners here in maple syrup land, thanks for the reply!
03-19-2021, 08:08 AM
Banned
Real Name: Tommy Bahamas
Banned
I had a mechanic knock out a bad bearing but it took 3 hours. Best to go with full assembly. Takes under 1/2 hours.
Amazon.com : 4runner wheel bearing
03-19-2021, 11:32 AM
Nothing wrong with RockAuto. They sell the same parts everyone else sells. I just put two in both front assemblies made by WJB. They have the same NGK bearings and they fit perfectly. Smooth....They had them on sale recently.... I bought 2 for $96 shipped. Now they are $108 each.
03-19-2021, 01:44 PM
I replaced mine with Beck/Arnley from Roackauto over 50k miles ago. Still going strong.
06 Galactic Limited on 33's, Rear locker, Bilstein 5100s, Toytec 2" Superflex Springs, Whitson Metalworks Rack, Squadron Sport Ditch Lights, Dual Viair 450cc Air compressors with 2.5 gal tank, Cobra 75WXST CB Radio
Build Thread: https://www.toyota-4runner.org/4th-g...ld-thread.html
01-24-2024, 10:23 AM
Real Name: Ron
Real Name: Ron
Originally Posted by Randyket
I had to replace my RF wheel bearing recently, and I went with a brand called Timken. Got it from nyzbearing store Home - NYZ Custom Most Suitable Bearing, and it's been holding up well so far. Not sure about Rock Auto, but I've heard mixed reviews.
Timken been making wheel bearings for decades.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
