Old 03-17-2024, 09:48 PM #1
parsky1 parsky1 is offline
parsky1 is on a distinguished road
2UZ FE 4.7L Dipstick Tube O-ring Replacement
2005 V8. Dealership wants $260 to replace a $3 O-ring on the dipstick tube where it goes into the engine. Doesn’t this thing just bolt onto the block with one bolt? Seems like a high Labor charge. Anyone done this before? Tips?
parsky1 is offline   Reply With QuoteReply With Quote
Old 03-18-2024, 08:24 AM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I just replaced the valve cover on passenger side on my'03 V8 and had the oil dipstick and trans dipstick unbolted for better access and I can tell you it was a real pita to get it bolted back in place. I wish I had a new oring at the time I would have replaced it then. This probably one of those jobs the dealer doesn't really want to do, BUT if you want to pay their price of course they will.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 03-18-2024, 09:54 AM #3
What made it so difficult to install again?
Old 03-18-2024, 01:21 PM #4
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Removing the securing bolt is easy, if it doesn't strip/break, but putting it back ideally takes two hands, one to align it, the other to start bolt, only room for one hand, so it took me over an hour to get the alignment and get the bolt to grab a thread. Lots of @#%&?>>!!
Now I would need to look at it again because I had both the Trans dipstick tube and oil dipstick tube securing bolts removed, but I think the trans is bolted to the oil dipstick tube via welded on bracket and you remove it first and the oil is secured to the block and is the pita to get back in place and bolt started. If it were the reverse then you can easily replace the oil dipstick tube oring, but I think not.
Old 03-18-2024, 01:25 PM #5
My 05 has the sealed transmission. So no dipstick for it.
Old 03-19-2024, 07:54 AM #6
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
In that case, yours might be a little easier.
Old 03-23-2024, 03:14 PM #7
Penetrating oil and a 12mm socket with a 12” extension made this easy. Just pull the passenger tire off. I cleaned it up with a toothbrush and brake cleaner so junk didn’t fall in. Old O-ring was a very hard disk. Saved $257
O-ring PN: 96721-19010
2uz , bolt , dipstick , o-ring , tube
Oil dipstick tube for V8 no longer available? Hunter61 4th Gen T4Rs 14 12-23-2023 02:11 PM
Motor Oil Dipstick TUBE hinmo24t 4th Gen T4Rs 2 10-22-2018 05:13 PM
Dipstick O ring- cause of leak Soulman 3rd gen T4Rs 11 12-01-2017 01:33 PM
I broke my Oil dipstick tube!!! popsmckracken 3rd gen T4Rs 21 07-14-2016 09:52 PM
