Old 03-19-2024, 07:56 PM #1
Ron_Mexico Ron_Mexico is offline
Ron_Mexico is on a distinguished road
Dash light randomly comes and goes every so often!!
Funny dash lights come on every so often and then off. This probably happens once every 3 or 4 months and then nothing. No check engine light, it’s VSC off, skidding symbol, ABS and VSC Trac. I even pulled over and used my OBD2 scanner while the lights are on to check for codes but nothing comes up. The lights eventually go off and everything seems fine.
Is something going on that I’m not aware?? Anyone else experience this too?? My 4Runner is a 2006 V6.
I also took a picture of the dash to show which lights are on.
Dash light randomly comes and goes every so often!!-img_4462-jpg
Ron_Mexico is offline   Reply With QuoteReply With Quote
Old 03-19-2024, 08:53 PM #2
vonRunner's Avatar
vonRunner vonRunner is offline
Real Name: Andrew
vonRunner will become famous soon enough
vonRunner's Avatar
Real Name: Andrew
I'm currently having the same issue... From my quick research so far it seems most people say to replace the brake switch located behind the brake pedal. The part # for the switch looks to be "84340-69025", but please also do your own research to make sure as I'm not 100% this is the fix yet...
2006 V8 Sport Edition
Build Thread
vonRunner is offline   Reply With QuoteReply With Quote
Old 03-20-2024, 09:12 AM #3
Zero0575's Avatar
Zero0575 Zero0575 is offline
Real Name: Casey
Zero0575 will become famous soon enough Zero0575 will become famous soon enough
Zero0575's Avatar
Real Name: Casey
You need a reader that reads ABS codes. Not all of them do. This is likely a fault in the ABS system, but cant be sure until you read the ABS codes. I had something similar years ago and it was a portion of the ABS wire harness being frayed somewhere, probably from when I installed the lift and cranked on things.
https://a.co/d/iIcMn5j
This is the one I have that reads ABS.
2007 Limited V8 | 275/70/18 Falken Wildpeak AT3W | Spidertrax | 4xInnovations Weld On Sliders | Victory 4x4 Blitz Front Bumper | RCI Skids | TNF Rear Bumper | Smittybuilt Winch | KOYORAD Aluminum Radiator |OME 886 Front/Toytec Superflex HD Rear and OME Shocks/Struts | JBA High Caster UCA | Rebuilt LCA with Superpro bushings + Moog BJ | HCF Delete | Doug Thorley Shorty Headers | Magnaflow HFC | Gibson Catback | Rear Diff Breather Extension | 20" Spot/Flood | 9" Spots | DD SS3 Yellow Fogs | Amber Grill Lights | Fog Lights Anytime Mod
Zero0575 is offline   Reply With QuoteReply With Quote
Old 03-20-2024, 07:37 PM #4
MikeinNH67's Avatar
MikeinNH67's Avatar
I agree with Zero, I had similar intermittent lights when I had a wheel sensor failing. Seems if we had some humidity or rain it would show up more. I bought a Foxwell 2 way scanner and could see one sensor was not incrementing properly when the lights were on.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 03-20-2024, 08:48 PM #5
SocalSam SocalSam is offline
SocalSam will become famous soon enough
Check wheel speed sensors. I am betting one is just dirty enough to interrupt signal every once in a while.
SocalSam is offline   Reply With QuoteReply With Quote
check , dash , light , lights , vsc
4LO light on randomly??? chayos00 4th Gen T4Rs 3 07-18-2023 01:12 PM
All dash lights lit up randomly on highway today Flybynight 4th Gen T4Rs 0 07-24-2020 09:00 PM
Battery light flickering randomly mlc2000 4th Gen T4Rs 6 02-18-2018 05:24 PM
Emergency Brake Light appears randomly apwdweb 3rd gen T4Rs 28 11-23-2017 03:03 AM
"Brake Engaged" Dash Light comes on randomly? WNC_KLR Problems & Warranty Issues 1 10-09-2012 05:13 AM
