Old 03-24-2024, 12:18 PM #1
Boxermachine Boxermachine is offline
Boxermachine is on a distinguished road
Trans line placement question- HELP Please
So the metal transmission lines under the radiator rusted out, I replaced it, but I'm unsure on the driver side connection. The rubber hoses both popped off on the drivers side at the same time and I am unsure as to which hose goes back where- Can someone please advise?
04 v6 SR5 4x4
Boxermachine is offline   Reply With QuoteReply With Quote
Old 03-24-2024, 01:36 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I have an '03 V8, not sure if they are the same, but the upper steel line coming out of transmission has a rubber hose on the end that connects to the inboard steel line going under the radiator across to the driver side where another rubber hose connects it to the topmost steel line on the air to oil cooler in front of radiator, then another rubber hose then goes into the top of that cooler. Make sense?
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 03-24-2024, 02:12 PM #3
Mine has two steel lines (that I replaced) under the radiator. On the driver side, going from the steel to the rubber lines, I'm still not sure which is a return and which is a feed.
04 v6 SR5 4x4
Old 03-24-2024, 07:17 PM #4
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
So does the V8, as I described. One takes the trans oil to the cooler, the other takes mine back to a cooler in radiator and then out of rad back to the trans.
drivers , popped , side , time , unsure
Trans cooler line part #'s AJPuleo23 3rd gen T4Rs 3 05-10-2021 06:08 PM
Add A Trans Temp Gauge to Cooler Line DanielMaat89 4th Gen T4Rs 11 06-03-2017 07:42 AM
Trans fluid over line littlehandegan 3rd gen T4Rs 2 11-08-2013 07:32 PM
CB Placement in dash question... BigStickKenobi Engines / Suspension / Wheels / Tires / Audio / Accessories 0 07-13-2012 06:08 PM
04 4runner air filter placement question beewee 4th Gen T4Rs 2 10-02-2009 10:18 PM
