Senior Member
Real Name: Ron
Senior Member
Real Name: Ron
I have an '03 V8, not sure if they are the same, but the upper steel line coming out of transmission has a rubber hose on the end that connects to the inboard steel line going under the radiator across to the driver side where another rubber hose connects it to the topmost steel line on the air to oil cooler in front of radiator, then another rubber hose then goes into the top of that cooler. Make sense?
__________________
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
