Old 03-28-2024, 10:05 PM #1
AndroT100's Avatar
AndroT100 AndroT100 is offline
AndroT100 is on a distinguished road
AndroT100's Avatar
Recirculating Air Servo Won't Turn Off
My recirculating air "flap" will close and open. The issue is that when I press the button to close it, the flap will close, and the servo turns off, but then after several seconds it will turn on again trying to close the flap that is already closed. At least this is what I assume it is doing as it is cycling/running.
Anyone else experience this issue and/or if so, anyone know if what the fix is or if I should even be concerned. It is noisy...not clicking like a broken one...just hearing the servo working.
Thank you!
2003 4Runner Sport V8 4x4
AndroT100 is offline   Reply With QuoteReply With Quote
Old 03-28-2024, 10:18 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I would guess maybe the switch is going bad, or whatever it is that makes the servo stop when closed is going bad, that could be something in the servo or maybe something on the door, either way at some point it could make the servo die, or not.
So you could replace one or the other and if it solves the issue you're good to go if not then replace the other, or just wait until it doesn't work at all and try and fix it.
2004 Limited V8
Old 03-29-2024, 09:55 AM #3
SocalSam SocalSam is offline
SocalSam will become famous soon enough SocalSam will become famous soon enough
Replace the actuator. If the position sensor or stop in the actuator is bad, it will run. It is located top right behind glove box.
SocalSam is offline   Reply With QuoteReply With Quote
Old 07-08-2024, 09:31 PM #4
AndroT100's Avatar
AndroT100's Avatar
Thank you!
This one?
Toyota 87106-35120 Damper Servo Sub-Assembly(For Mode)
2003-2014 Toyota 8710635120
Part Description
Servo Sub-Assy, Damper(For Mode)
Part Name Code
87106J
Comment
(FOR MODE)
Manufacturer
Toyota
Old 07-09-2024, 03:52 PM #5
Originally Posted by AndroT100 View Post
Thank you!
This one?
Part Description
Part Name Code
87106J
Comment
(FOR MODE)
Manufacturer
Toyota
87106 looks right. If you can reach the connector and unplug it, diagnosis would be confirmed.
Old 07-09-2024, 04:16 PM #6
Real Name: Skip
Real Name: Skip
Thank you!
This one?
Part Description
Part Name Code
87106J
Comment
(FOR MODE)
Manufacturer
Toyota
87106 is the first part of the part number for all of the actuators, it's the second part of the part number that is different for each one.
I would highly suggest contacting the dealer you're buying from along with your VIN number and let them tell you which one is the correct one.
I tried yesterday to find the part number you need but the diagrams on the dealer's website had conflicting info.
2004 Limited V8
Old 08-17-2024, 04:21 PM #7
AndroT100's Avatar
AndroT100's Avatar
I apologize for delay in responding!
Many thanks!
I like the idea of disconnecting to zero-in on which part is needed. The door opens and closes, so it does seem that it is the actuator...I do need to confirm which one it is....
air , close , flap , recirculating , servo
WTB: 4th Gen Servo AC Parts SHagood For Sale: T4R Items 0 09-18-2019 02:30 PM
WTB air mix servo motor lildozer74 Want to Buy/Trade 0 02-18-2015 10:09 PM
heater servo fix baskelh 3rd gen T4Rs 1 02-09-2014 11:50 PM
recirculating mode keeps on going to outside air... Restricted_10 Problems & Warranty Issues 0 11-20-2011 11:27 PM
A/C Servo? CLewis General Discussions 1 05-07-2008 09:06 PM
