Old 03-31-2024, 01:58 PM #1
chisel's Avatar
chisel chisel is offline
chisel is on a distinguished road
chisel's Avatar
Check ATF fluid level after exchange - at what point is the vehicle level?
Hello everyone,
I think I've read every post here wrt performing the ATF exchange. Doing it today on a (new to me and first 4th gen.) 2008 Limited 4x4 V6. Due to a leaking X-REAS and sloped floor, how do I know when the vehicle is level to check the ATF fluid level? The FSM shows the top of the oil pan level, but I'd have to jack up the back end of the vehicle quite a bit to get to that point. That can't be right. With the factory running boards level and the frame the same or close, then the bottom of the pan is not level and neither is the top, not by a long shot.
What's the solution? Get the frame level and check the ATF fluid in that position?
2008 Limited 4x4 V6
chisel is offline   Reply With QuoteReply With Quote
Old 03-31-2024, 02:30 PM #2
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
Originally Posted by chisel View Post
Hello everyone,
They designed it to cope with steep gradients etc...I'm sure there's enough of a designed in "over fill" that you don't need the truck level to the millimetre. My last one wasn't, I think I just put a spirit level on the running boards and across the rear bumper, and the gearbox was fine afterwards, right up until I stuffed it into the Armco.
I spent more time making sure I got the temperature right for the level check procedure etc etc than I did getting it spot on level.
My new one has the previous transmission, with (Thankfully) this thing called a dipstick. Maybe they will catch on?
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
Old 03-31-2024, 05:06 PM #3
chisel's Avatar
chisel's Avatar
Thank you Surfer. Good point about the steep gradients. I didn't think about that.
2008 Limited 4x4 V6
Old 03-31-2024, 05:21 PM #4
SurferUK's Avatar
SurferUK's Avatar
I had to talk myself down from overthinking it too. It's all good.
Old 03-31-2024, 06:45 PM #5
parsky1 parsky1 is offline
parsky1 is on a distinguished road
I just carefully capture what I drain, mark the line on a 5 quart graduated container and refill with new using my homemade ATF bong made out of urethane tubing and a cheap funnel. It’s a bit of work to get all the ATF out of the tubing, best to have two people, but it beats having to do the stupid warm up and pull the plug. I leave the ATF and vehicle in the garage overnight so they are the same temperature in the morning.
parsky1 is offline   Reply With QuoteReply With Quote
Old 03-31-2024, 08:00 PM #6
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
This method will work great....IF you were at the correct level to begin with, if not you will be low or overfilled on ATF, which nether is good, it's best to properly check the ATF level to be certain you don't damage your very expensive transmission!!
2004 Limited V8
Old 04-09-2024, 10:46 AM #7
grumpy02 grumpy02 is offline
Real Name: Stan
grumpy02 is on a distinguished road
Real Name: Stan
How did you measure the temp? I have A/T temp readout on Torque Pro. Is that OK to use?
grumpy02 is offline   Reply With QuoteReply With Quote
Old 04-09-2024, 01:52 PM #8
SurferUK's Avatar
SurferUK's Avatar
I just used a hooky copy of that Toyota Techstream programme and a laptop. Basically the same thing. I knew it had to be between a certain temperature range but with the engine running, so wasn't sure how much of a window of time I had before it went out of range.
Old 04-09-2024, 06:09 PM #9
Real Name: Skip
Real Name: Skip
Yes you can use the Torque Pro readout for the proper temperature.
2004 Limited V8
Old 04-09-2024, 06:20 PM #10
Offroad Alliance Offroad Alliance is offline
official vendor
Offroad Alliance is on a distinguished road
official vendor
simply park on level ground or a garage usually is fine. The frame being "level" is what is ideal, dont mind the shape of the pan as there are lower sections to house the fluid so the "pull" neck doesnt go dry from steep gradients as mentioned above.
On the trail I get severe trans temp fluid warnings if I am nose high and past a 65 degree angle and am having to "crawl" from the fluid not being able to be pulled and cycled properly through the system. after getting level ground again I have to let the truck sit and idle for a few minutes to level the temps out.
Torque Pro for readouts is a great solution
Offroad Alliance is offline   Reply With QuoteReply With Quote
Old 04-11-2024, 09:56 AM #11
Real Name: Stan
Real Name: Stan
Thanks for the confirmation that the temp readout from Torque Pro is good.
atf , check , fluid , level , vehicle
ATF Fluid Level Check - Why is This Happening? Bluesky 07 4th Gen T4Rs 17 03-02-2022 03:57 PM
how to check transmission fluid level? Idgy Maintenance/Detailing 14 01-03-2022 05:05 PM
Check Transmission Fluid Level (5th Gen) the_dude_abides 5th gen T4Rs 4 08-18-2020 11:28 PM
No need for temp check mode: Eas(ier) ways to check WS transmission fluid level JB. 4th Gen T4Rs 36 11-02-2019 11:48 AM
Lifted 4runners and ATF Fluid Level Check blackfc3s 4th Gen T4Rs 2 04-28-2017 03:43 PM
