Old 04-02-2024, 07:54 PM #1
Kevin G. Kevin G. is offline
Kevin G. is on a distinguished road
Leak Detection Pump......the internal dc motor
It's on the 4th gen Evap Canister assembly.
Similar to the logic we use when replacing the door lock actuator motor.
Anyone had the pump apart, and identified the small dc motor?
Thanks,
Kevin
Kevin G. is offline   Reply With QuoteReply With Quote
Old 04-06-2024, 02:05 AM #2
Come on guys.......
Surely someone has taken the EVAP canister pump assembly apart.......and identified the small internal dc motor.
Post up!
Thanks,
Kevin
Old 05-06-2024, 08:39 PM #3
Well..........finally got around to replacing the leak detection pump on the evap canister assembly.
Next.....is to clear the codes......and wait......to see if they reappear.
I'll be taking the pump apart, to see if I can identify the small vacuum pump dc motor.
Still.........it's hard to believe that no one has identified the little motor.
Later,
Kevin
Old 05-07-2024, 11:06 PM #4
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
Later,
Kevin
I've never seen a post about this so maybe not a common issue?
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 05-08-2024, 04:44 AM #5
Guess I should have listed the thrown codes.
P043E
P043F
P2402
P2419
P2401
BTW.........it was NOT the gas cap.
My main point is that the REAL problem boils down to the small dc leak detection pump......5-10 dollar motor.......and not the entire $800 evap canister assembly.
Hope this helps.
Kevin
Old 05-11-2024, 02:00 PM #6
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
P043E
P043F
P2402
P2419
P2401
Hope this helps.
Kevin
How easy was it to disassemble and change the motor? What specs were the new motor?
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
Old 05-11-2024, 11:09 PM #7
Have not tried that yet. I'll post once I can id the motor.
Kevin
door , leak , lock , motor , pump
2001 ABS pump motor-best place to buy rebel4x468 3rd gen T4Rs 4 11-29-2017 01:30 PM
Internal headliner LEAK (fixed) neatoneto 5th gen T4Rs 5 06-04-2017 10:40 PM
Noisy Motor/pump imanabsolutezer 3rd gen T4Rs 6 02-03-2010 04:26 PM
Noisy Motor/pump imanabsolutezer Problems & Warranty Issues 1 01-28-2010 05:31 PM
