Old 03-30-2024, 05:36 PM #1
simple's Avatar
simple simple is offline
simple will become famous soon enough
simple's Avatar
Spark Plug Concerns
I've had my current V6 08 for about 5yrs. I thought the spark plugs were changed before I got it around 110K. Looking at the carfax, it was actually done at 59K, has 170K today. There were NGK Iridiums in there, and I just replaced them with the same.
Passenger side were hard to get out, like there was anti-seize on the threads or something. Driver side all came out really easy, and felt undertorqued compared to the passenger side. The middle driver side had orange like burnt marks on the ceramic, and looked like it could have been wet. The rear one was definitely wet, and when i looked in the engine chamber, there was a little bit of moisture by the threads area.
All of the spark plugs were worn down to a .75 to .85 gap.
I did have an oil analysis done very recently, and the oil looked good, although they found a trace amount of fuel in it. I had the same trace reading at 135K, but not 160K.
Any idea what could be going on here, and how much trouble I'm in?
Air 4rceRunner One, 04 Sr5
simple is offline   Reply With QuoteReply With Quote
Old 03-30-2024, 06:06 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
It's not a big issue, that just oil that leaked past the valve cover spark plug hole seal, that oil can't really go anywhere other than around the spark plug.
To solve the issue if you choose too is to replace the valve cover gaskets as well as the valve cover spark plug hole seals, just checking to see if the bolts for the valve covers are torqued properly may stop the leak/s if they're loose.
2004 Limited V8
Old 04-02-2024, 09:58 PM #3
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
If you're worried about something like a failing head gasket, you can test the coolant for exhaust gasses. Otherwise I'd change the plugs and monitor things like coolant levels and such.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 04-09-2024, 10:38 AM #4
grumpy02 grumpy02 is offline
Real Name: Stan
grumpy02 is on a distinguished road
Real Name: Stan
Like Mike said above, just put in new plugs & keep a close watch on coolant levels. If you are really worried, get a cheap borescope to hook to your phone & see if there is any coolant in the combustion chambers.
grumpy02 is offline   Reply With QuoteReply With Quote
driver , looked , side , spark , wet
spark plug rounded, remove spark plug tubes? Danger Mouse 3rd gen T4Rs 0 05-02-2021 03:43 PM
Spark plug concerns? Normal wear?? zguy1 4th Gen T4Rs 9 12-08-2020 09:27 PM
Spark Plug (Coil-On-Plug) Boots at RockAuto.com! RockAuto Rockauto 0 01-12-2017 02:52 PM
Spark Plug Help kpnavarro Classic T4Rs 2 12-04-2012 09:40 PM
which spark plug ? davem Engines / Suspension / Wheels / Tires / Audio / Accessories 1 09-20-2008 09:26 PM
