Old 04-11-2024, 10:52 AM #1
Monty87ls Monty87ls is offline
Monty87ls is on a distinguished road
Need some help! Electrical issue?
Hi, earlier today I started my 04 4runner with the remote starter and proceeded outside shortly after. Decided to finish hooking up the hardwire for my dash camera so I used the remote to turn it back off.
Installed the wire which took 2 minutes and bam it won't start. I have all lights but won't turn over, later noticed I've lost my radio and keyless entry too. The remote starter will lock and unlock the car but yhe factory fobs don't work. Tried both and nothing.
Checked fuses and all seem good.
Any ideas? Thanks!
Sent from my SM-S918U using Tapatalk
Monty87ls is offline   Reply With QuoteReply With Quote
Old 04-11-2024, 11:24 AM #2
Offroad Alliance Offroad Alliance is offline
official vendor
Offroad Alliance is on a distinguished road
official vendor
Without any pictures or knowlegde how you hard wired it, I would start with your wiring. How did you hard wire it and what did you hard wire it to? Did you go to a fuse or did you tap an existing wire? Have you disconnected the wire you installed and see if that lets the vehicle start again?
Maybe some pictures or where/how it was wired would help
Offroad Alliance is offline   Reply With QuoteReply With Quote
Old 04-11-2024, 02:16 PM #3
It was just a fuse tap into the fuse box by the dash. Same as I did on other vehicles and on this one before . I took it back out as soon as it didn't start. I did leave the ground connected but it's just behind a bolt on the body behind the plastic kick panel.
I can take some pics if needed but it's disconnected now. Takes less then a min to do it
Old 04-11-2024, 02:22 PM #4
I plugged it into fuse 37 power outlet. Once the car didn't start I took it back out.
Old 04-11-2024, 03:44 PM #5
*insert facepalm emoji* so when I went to install it started raining so I started rushing. I saw a bolt and started undoing it and quickly realized it wasn't on the body so used another one. Apparently it was to the harness or something because it disabled the ignition, radio, front and rear wipers, turn signals and heater controls.
Fixed now! Now back to trying to figure out why the horn doesn't work!
Old 04-11-2024, 04:23 PM #6
official vendor
official vendor
fixed one thing, onto the next!
Horn not working, that happened the same time as all of this? check the fuse?
Old 04-11-2024, 04:39 PM #7
Nope. This started a year ago when the truck was off the road. I decided to see if the horns from it would work plug and play onto my rav4 since those horns suck. They didn't but when I plugged them back in they stopped working. The fuse looked fine but I honestly haven't taken anymore time to figure it out but need to! I'm in NY and the amount of people I need to beep at on a daily basis is ridiculous lol
They worked before it, didn't after all within a 10 min time frame
Old 04-11-2024, 05:15 PM #8
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Bad horn relay?
2004 Limited V8
Old 04-11-2024, 08:31 PM #9
Originally Posted by AuSeeker View Post
Bad horn relay?
Gonna look into it. Maybe I did something to it when I unplugged them idfk. But now that it's on the road I'm gonna figure it out
lock , remote , starter , turn , unlock
Electrical Issue goatfarmer Classic T4Rs 2 03-01-2023 06:55 PM
Electrical issue help jam23r1 5th gen T4Rs 26 05-13-2021 12:42 PM
Electrical Issue? 1985taylor1925 3rd gen T4Rs 42 04-16-2013 07:24 PM
Serious Electrical Issue!!! APS LLC 4th Gen T4Rs 1 05-11-2012 10:49 AM
