Old 04-11-2024, 09:59 PM #1
mastee mastee is offline
mastee is on a distinguished road
Hyperflash L Turn signal, DMM shows 0.617 Amps max
Hi,
My left turn signal has a pigtail harness connected to it and it hyperflashes, there are no LED anywhere, and I have looked at all the bulbs, the Hazard flashes all sides fine.
I connected a DMM to see the current draw and saw it fluctuate between 0.002 Amps and 0.617 Amps on the high end (but saw values a bit lower as well e.g. 0.5ish).
Does this means that the relay behind the fusebox is ok or shot?, any ideas how may I troubleshoot this further?
mastee is offline   Reply With QuoteReply With Quote
Old 04-12-2024, 09:38 PM #2
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Have you checked all the lights on both front and rear of the L side?
Old 04-22-2024, 03:33 PM #3
andynj andynj is offline
andynj is on a distinguished road
Did you check the light harness in the front driver side, its common for that to get water in and burn out and do weird things. Mine would hyperflash after rain sometimes and when I pulled it out it was all burnt up in side. Its this part, super easy to change out.
Amazon.com
andynj is offline   Reply With QuoteReply With Quote
amps , connected , dmm , signal , turn
2014 left turn hyperflash sorry oljedi11950 5th gen T4Rs 2 01-16-2024 01:28 PM
Turn Signal LED Hyperflash Solution knightsfs4 4th Gen T4Rs 15 06-04-2023 11:14 AM
FS: 5th Gen Lasfit front turn signals. Canbus no Hyperflash no resistor Bayonne Nj 0 skillzo1 For Sale: T4R Items 1 04-05-2020 10:29 AM
Demello LED turn signal and hyperflash- Has anyone solved this issue with a resistor? PAULUNM 4th Gen T4Rs 7 11-05-2014 11:30 PM
Turn signal help jfeg 4th Gen T4Rs 8 10-21-2014 08:36 PM
