Old 04-18-2024, 10:50 PM #1
Ratubbs's Avatar
Ratubbs Ratubbs is offline
Ratubbs is on a distinguished road
Ratubbs's Avatar
Annoying sound !!
Why does it sound like there’s a styrofoam cooler squeaking from under my cargo area ?!?!
I’ve lubed everything under there that has a joint or connection , spare tire is tight so I’m at a loss . All I know is it’s annoying AF
Ratubbs is offline   Reply With QuoteReply With Quote
Old 04-19-2024, 08:03 AM #2
OopsIBrokeIt OopsIBrokeIt is offline
OopsIBrokeIt will become famous soon enough
Exhaust hangers maybe? They're notoriously a source of squeaking sounds.
OopsIBrokeIt is offline   Reply With QuoteReply With Quote
Old 04-19-2024, 08:06 AM #3
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
There is styrofoam under the rear bumper cover, between it and the steel bumper-like cross member, at least there is on my 4th gen. To access it you have to remove the bumper cover, which really isn't difficult.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 04-19-2024, 08:52 AM #4
SocalSam SocalSam is offline
SocalSam will become famous soon enough
Hatch release adjustment?
SocalSam is offline   Reply With QuoteReply With Quote
Old 04-20-2024, 09:40 AM #5
Ratubbs's Avatar
Ratubbs's Avatar
If you could elaborate a bit more I can give it that a try. But it truly sounds like it’s from under the cargo area .
Old 04-20-2024, 09:42 AM #6
Ratubbs's Avatar
Ratubbs's Avatar
UPDATE: I drove in to work this morning in the rain and the sound was absent so now I’m thoroughly confused ??
Old 04-20-2024, 09:55 AM #7
Ripper238's Avatar
Ripper238's Avatar
There is 4Runner-foam under the cargo area (more/less depending on model). Sound deadening/insulation. It will likely make the noise you hear and change depending on temp and humidity. It's usually not an issue.
Pulling the Rear seats from a 5th Gen 4Runner | Complete Rear Seat and Cargo Removal | Gutting Bruce - YouTube
Old 04-20-2024, 10:41 AM #8
Possibilities. Latch squeaks on the catch loop when body flexes over rough road. Catch loop may be corroded from wear. Simply remove and reverse sides to present clean side to latch. Could also be worn gas lift struts that are not applying tension to the latch and catch which would reduce play.
annoying , connection , it’s , loss , sound
What is this annoying sound from brakes? Biking4jesus 4th Gen T4Rs 5 06-12-2019 04:04 PM
Faint but annoying sound from passenger side?!?! jimmied 4th Gen T4Rs 0 12-03-2013 08:47 PM
What's this annoying sound? tomzapf 3rd gen T4Rs 5 01-15-2013 11:48 AM
Annoying Weird Sound Bigmikelakers 3rd gen T4Rs 1 02-08-2012 07:01 PM
Annoying buzz sound from cig lighter w/ipod?? CRDT4R 4th Gen T4Rs 9 11-26-2008 10:30 PM
