Old 04-24-2024, 10:35 AM #1
4R005 4R005 is offline
4R005 is on a distinguished road
Jacking up vehicle using front diff ?
Can one lift up the front of their 4R with a floor jack under the front diff and not do damage, like one can do with the rear diff ?
My ride is a 2005 4R w/V8.
I lift and place jack stands under front frame rails now. Not planning to crawl under vehicle if OK to lift from the front diff.
Appreciate all comments. Thks.
4R005 is offline   Reply With QuoteReply With Quote
Old 04-24-2024, 04:30 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
You need and suppose to have the jack under the cross member, I wouldn't lift it placing the jack under the diff, it most likely wouldn't damage anything but it's not where it's supposed to be lifted from, if you still have the OEM skid plate installed it has reinforcement on it up to the cross member so you don't have to remove the skid plate to jack up the vehicle.
Your owner's manual has jacking points noted in it.
2004 Limited V8
Old 04-24-2024, 06:08 PM #3
bendover717 bendover717 is offline
bendover717 is on a distinguished road
Definitely possible, recommended, NO
bendover717 is offline   Reply With QuoteReply With Quote
Old 04-29-2024, 03:37 PM #4
Thanks for the input, all. No jacking from the front diff, then. Best be safe than sorry.
Thought that lifting from a central point will save me from going one side and then the other dragging the hydraulic lift to get at the front rail's jacking points.
Getting lazy in my old age. lol.
Old 04-29-2024, 06:36 PM #5
Real Name: Skip
Real Name: Skip
If you put the jack under the front frame cross member and in the middle, you will be jacking up both sides at once, it's the same as if you were jacking at the diff only a little further back.
2004 Limited V8
diff , front , jack , lift , vehicle
Vehicle weight capacity with Diff Lock Shamish 5th gen T4Rs 14 12-20-2021 12:53 PM
Front Diff magnetic plug worse than Rear Diff normal? Rpede 5th gen T4Rs 0 03-08-2021 05:00 AM
noise jacking front end up hankd 4th Gen T4Rs 9 08-27-2020 08:43 AM
Front diff gear ratio verification - diff removed and no vehicle info SDmtnbkr 3rd gen T4Rs 6 07-26-2017 09:39 PM
driving a diff 4WD vehicle jediwebdude Off Topic 4 09-23-2012 04:17 PM
