Old 04-26-2024, 10:36 AM #1
simple's Avatar
simple simple is offline
simple will become famous soon enough
simple's Avatar
Spare Tire Winch Love PSA
A couple weeks ago I had to remove my spare tire for a bit. NBD. When I went to winch it back up, it was stuck. I could pay out but not retract. With or without the tire. I was finally able to get it to come up bouncing the handle mechanism left and right until it would unlock, but only an inch or 2 at a time. Was looking at the cost of replacing the unit thinking it was toast, but decided to try and lube it. I sprayed the hell out of the cable, inside the winch box, and the assembly where you input the rotation bar.
Fixed it right up, but tried it the next day… not fixed. I went back in and did it again. A few weeks later, I went to spray it one more time before I hit a road trip and it was smooth as butter. I’ll definitely be doing this, at least spray by a small amount periodically. Having to replace the winch looks like a PITA.
I used WD-40 specialist silicone quick drying spray. Wanted to pass this on as our trucks get older and we neglect some areas we don’t think about.
Air 4rceRunner One, 04 Sr5
simple is offline   Reply With QuoteReply With Quote
Old 04-27-2024, 06:46 PM #2
SocalSam SocalSam is offline
SocalSam will become famous soon enough SocalSam will become famous soon enough
Must be a beach truck. I winched down my spare to check date code. It was the original spare which means winch may never have been worked. Mine came down and went up smooth as butter.
SocalSam is offline   Reply With QuoteReply With Quote
Old 04-28-2024, 10:34 AM #3
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb is a jewel in the rough ArthurKotb is a jewel in the rough ArthurKotb is a jewel in the rough
ArthurKotb's Avatar
Real Name: Rich
I had almost the exact same experience. The back and forth while spraying the gear mechanism with Liquid Wrench white lithium grease did the trick for me. I think I was able to pry open an edge of the gear box a little but maybe not. It's not been stuck since then and now every year I drop the spare and lube it some more.
I do not go off-road but the car is parked outside, no garage. I rarely drive it in the snow to avoid salt corrosion.
I agree that it looks like a real problem to replace. I found a YouTube video for a Land Cruiser and that cross member the gearbox is mounted on was bolted to the frame, not welded. A shame that Toyota chose to weld it on the T4Rs.
Spare Tire Winch Love PSA-spare-lithium-grease-jpg
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 05-01-2024, 10:30 PM #4
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
I lube mine in spring and fall to keep it working. It was frozen when i got the truck but I got it freed up. For awhile, there was someone posting a PSA twice a year for this.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
fixed , spare , spray , tire , winch
PSA: Exercise your spare tire winch! rwh963 4th Gen T4Rs 10 08-03-2019 07:16 PM
WTB 4th gen Spare Tire Winch/Hoist Brooklyn@3260 Want to Buy/Trade 3 04-27-2016 05:11 PM
Spare Tire Winch smokey7722 4th Gen T4Rs 12 01-02-2011 05:51 PM
