Old 04-26-2024, 04:09 PM #1
Monty87ls Monty87ls is online now
Monty87ls is on a distinguished road
Horn Not Working
Pretty sure I did a post on this maybe a year ago but I couldn't find it.
04 Sport horns have stopped working. They were working fine and one day I decided to see if they would work on my rav4. I took them off swapped and they didn't work so put them back on the 4runner. Since then they stopped working.
This was probably over a year ago and it was off the road but now back on so I wanna fix the issue. Checked fuses and they are fine, Swapped the relay behind the dash with the one next to it and didn't work. Can hear a clicking when pushing on the steering wheel.
Any other suggestions? Thanks
Monty87ls is online now   Reply With QuoteReply With Quote
Old 04-26-2024, 05:23 PM #2
Offroad Alliance Offroad Alliance is offline
official vendor
Offroad Alliance is on a distinguished road
official vendor
all you did was unplug them and transfer to another vehicle then move them back?
Offroad Alliance is offline   Reply With QuoteReply With Quote
Old 04-26-2024, 05:43 PM #3
FoundedSine14's Avatar
FoundedSine14 FoundedSine14 is offline
FoundedSine14 will become famous soon enough
Have you checked the grounds? Use a multimeter to verify continuity from this part of the horn to the frame
2008 SR5 | Build Thread
2006 AutoX Camry | Build Thread
FoundedSine14 is offline   Reply With QuoteReply With Quote
Old 04-26-2024, 05:49 PM #4
official vendor
official vendor
Also make sure pins in the connectors arent bent or wires havent come loose. Its a fairly dumbproof system but ive seen where the horn was tied to the radio and some other components so make sure youre fuses are good. Sometimes replace the fuse regardless if it "appears ok"
Old 04-27-2024, 08:07 AM #5
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
YES. I had a no horn work problem on my Matrix, pulled the ground fastener and it was corroded, but looked ok, replaced it with a fresh fastener and bingo, horn worked.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 04-27-2024, 08:48 AM #6
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
If you hear a clicking under the hood when you press the horn button on the steering wheel then the relay should be working. Check the voltage at the horn connection when the horn button is pressed. To check the horn, run a jumper wire from the positive post to the horn's connector. (You can also remove the horn from the car and put the connector tab on the negative post and the jumper wire on the positive.)
The relay could be working but still not providing voltage to the horns. It could have a burned connector inside. If you have voltage at the horn connector then the horn is bad.
On an old '91 Camry I had both horns quit at the same time. Sounds strange but they did. I replaced the relay and nothing. I checked voltage at the horn and it was 12.7 vdc. I bought new horns, problem solved.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 04-29-2024, 12:21 AM #7
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
horn fuse and go from there, check the wires going to the horn for power like other suggested.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
fine , stopped , swapped , work , working
Car horn not working kiyeoul 5th gen T4Rs 51 08-08-2023 12:57 PM
Horn Stopped working...Help Please '01T4R 3rd gen T4Rs 28 02-01-2018 06:45 PM
Horn not working crosso 4th Gen T4Rs 1 09-28-2011 08:37 PM
horn not working robert8629 3rd gen T4Rs 2 03-13-2010 11:54 PM
Horn not working.... el_jefe 3rd gen T4Rs 2 10-17-2008 09:04 AM
