Old 04-28-2024, 10:27 PM #1
coolkidd coolkidd is offline
coolkidd is on a distinguished road
2006 sport electrical issue
I have an 06 sport 4.0l, just today with it turned off and the key out the rear windshield wiper was running, as well as the front running lights not turning off. I checked the fuses and installed a new battery, it's still happening. now the cabin fan is turning on and off by itself, all with the vehicle off and the key out.
when it started I could hear clicking from the fuse box under the hood as the wiper would turn on and off. Any ideas what this might be? Any help would ve greatly appreciated.
coolkidd is offline   Reply With QuoteReply With Quote
Old 04-29-2024, 12:16 AM #2
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
sounds like a stuck relay or a wire that is shaffed and rubbing on a ground. check all wires inside and out, possible rodent damage? loose grounds worn ignition switch?
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 04-29-2024, 10:13 PM #3
Not sure about rodents, it's garaged with no visible signs of them. I'm leaning towards ignition switch. we'll find out tomorrow, I have an appointment at the dealership to get a diagnostic done.
Old 04-29-2024, 10:48 PM #4
riceandpho's Avatar
riceandpho's Avatar
if you can remove the lower dash area at the knee, its not hard to unplug the harness from the ignition switch to confirm.
it could be something simple, anything else was done to the vehicle?
Old 05-07-2024, 09:11 PM #5
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
Start by checking the relays in the fuse box. Also, damaged wiring could be causing the problem. And I’d check the grounding points too. Use a multimeter to test the voltage and continuity of the affected circuits.
weberlukas74 is offline   Reply With QuoteReply With Quote
Old 05-07-2024, 09:12 PM #6
key , running , sport , turning , wiper
Electrical Issue goatfarmer Classic T4Rs 2 03-01-2023 06:55 PM
Electrical Issue, Need Help! McLoven1t562 3rd gen T4Rs 28 09-07-2022 06:17 PM
Help with 06 4R Electrical Issue jacksjj 4th Gen T4Rs 1 07-06-2020 11:33 PM
Electrical Diagram For 2006 4Runner ts9790147 4th Gen T4Rs 5 12-11-2019 02:04 PM
electrical issue help kutch_classic 3rd gen T4Rs 12 10-15-2014 09:40 PM
