Old 05-03-2024, 01:25 AM #1
harojs harojs is offline
harojs is on a distinguished road
Location of moon roof drain outlets
2006 4runner Sport
Location of moon roof drain outlets - I can't find them.
[W]here exactly do the two drain outlets exit the body? Pics?
I need to clean the drains from the outlet up to the moon roof because my moon roof cable is stuck shut and I can't clean from the top drains down as you would normally.
harojs is offline   Reply With QuoteReply With Quote
Old 05-03-2024, 09:38 AM #2
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
Sound Deadening and New Audio Setup
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 05-14-2024, 08:04 PM #3
Found where the drain tube exits
Found where the drain tube exits into the lower area inside the drivers side quarter panel behind the mud flap.
That area behind the mudflap was packed full of little seeds and the drain tube got plugged.
I had to remove the mudflap screws and clips and was sort of able to vacuum out that area using a stick.
Still not happy clearing that area out - now way to open it.
How would you get in there? - remove the quarter panel?
John
Old 05-14-2024, 09:16 PM #4
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Moonroof Drain Locations (Underside)
Sunroof leak = Drains clogged. Help pleaee
4th gen sunroof rear drain exit location
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
drain , location , moon , outlets , roof
Rear Sunroof Drain Location Montego Murph 4th Gen T4Rs 5 07-18-2018 09:34 PM
AC Drain hose location? marshall87 3rd gen T4Rs 20 01-07-2016 06:58 PM
3RD Gen 4Runner moonroof drain tube location? hawkcharmer 3rd gen T4Rs 4 10-08-2014 08:48 PM
engine oil / transmission oil drain plug location Ross Maintenance/Detailing 0 07-05-2011 10:46 AM
Help Quick--Location of Oil Drain Plug? cmj685 4th Gen T4Rs 13 08-14-2005 11:55 AM
