Old 05-07-2024, 01:32 PM #16
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
Originally Posted by beautifulbrick View Post
Landcruiser Prado aka Colorado is the same platform. A rear axle should have all the correct link mounts etc.
Regular Hilux will be leaf spring and therefore won't be a direct swap although I believe they do use the same axle.
Unsure if there was a surf equivalent for the 4th gen, I think it just moved over to the Prado.
My '04 is coil spring and the Hilux was available in '04
rear wheel no alignment possible?-photo_2024-05-07_131652-jpg
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 05-08-2024, 01:07 PM #17
beautifulbrick beautifulbrick is offline
beautifulbrick is on a distinguished road
Understood, I wasn't sure about the Hilux surf as I've only had experience with the regular Hilux.
Out of interest what engine does the that gen surf come with?
beautifulbrick is offline   Reply With QuoteReply With Quote
Old 05-08-2024, 01:37 PM #18
ArthurKotb's Avatar
Real Name: Rich
ArthurKotb's Avatar
Real Name: Rich
It had a couple of options, including diesel.
I have the interior options catalog too. Among all the various color light replacements and seat options there's a step that is at the rear bumper. I would assume it's for the 3rd row seat.
rear wheel no alignment possible?-screenshot_20240508_133116_google-jpg
Rich
Kentucky
Old 05-09-2024, 01:58 AM #19
Jan777 Jan777 is offline
Jan777 is on a distinguished road
what about bearings?
Maybe this would be a solution to the wheel camber? The guy in the video has a different problem, no camber on his wheels, but if the bearings are shot this might cause the poblem I have with my T4R.
Anyone has experience with that?
see changing wheel bearing rear axle T4R: https://www.youtube.com/watch?v=xvQybhW_nbI
Jan777 is offline   Reply With QuoteReply With Quote
Old 05-12-2024, 05:10 PM #20
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
I was thinking the same thing!
For the OP: check your bearings, if you have a lot of "wobble" it could very well change your camber.
But if that's not it then I would say a bent axle. I'm sure it could be straightened, but I don't know how accurately. Considering that there are shops that can straighten a car frame: why not an axle?
https://www.youtube.com/watch?v=_PHwLcgfnO8
1997 4Runner SR5- ~376k Miles and counting
2007 4Runner Limited V6- 175k Miles
2011 VW JSW TDI- 150k Miles
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Old 11-14-2024, 11:20 AM #21
freak accident!
So I found out what caused the uneven waer of my rear tires. It sounds freakishly strange, and if it had not happened to me, I would not believe that this is possible.
The last time I changed tires, the tire shop did not fasten the fasteners on the rear left side properly. I drove with a loose wheel for many thousand miles, with the fasteners coming off more and more. I was puzzled why the rear tires were extremely worn down on the inner side and could not find the reason. Then the wobble got so bad that I stopped on the highway and noticed that on the left rear wheel only two fasteners remained, both of them very loose. The other four had come loose and had fallen off.
It is weird, I know and I expect all kind of comments like "this is not possible". But this is what happened.
So I took off one fastener from each of the three remaining wheels, fastened it to the wheel where fasteners were missing and made it back to the mechanic.
The mechanic just had to put new fasteners on, and did not even have to change the bolts.
The main damage was one bearing that had to be changed, since it got damaged by the wobble. But that was all!
My conclusion: I will NEVER EVER trust a tire shop again! I will always carry my manual wrench with me in the car and check the wheels manually after changing tires.
Old 11-14-2024, 04:18 PM #22
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
Thanks for the update, very annoying someone messed up your vehicle but at least there wasn't an accident and the axle is OK.
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
Old 11-14-2024, 10:31 PM #23
armabill armabill is offline
armabill is on a distinguished road
Don't trust dealers either. My son has a Highlander and when he left the dealer after a state inspection, on one rear wheel all of the lug nuts were loose.
He heard the noise immediately, stopped and tightened them down. If he didn't hear it, it would have been a real problem later on down the road.
No damage happened but it shouldn't have occurred at all.
armabill is offline   Reply With QuoteReply With Quote
Old 11-15-2024, 10:26 AM #24
ArthurKotb's Avatar
Real Name: Rich
ArthurKotb's Avatar
Real Name: Rich
On the evening news from time to time you will see a video of a vehicle that had loose lug nuts and the studs snapped off, the tire rolls down the highway and slams into another car, killing the occupants.
EVERY tire shop I have ever been to in all my years of driving will not put the lugs on properly; either too loose or too tight. I have a torque wrench and I loosen and tighten each one to Toyota specs any time my wheels are removed. (Clean the studs and lugs but never oil or grease them.)
Alloy wheels should be checked periodically as they can loosen on their own. Your owners manual probably has this caution in it in the section on changing a tire.
Rich
Kentucky
Old 11-16-2024, 01:57 AM #25
Hungryhawk Hungryhawk is offline
Hungryhawk is on a distinguished road
Are you rotating tires at 5k miles/8k kilometes?
Could those rear tire have been on front of truck?
Are the wheels/ rims checked for issues?
Tires are easy to change. Why not just rotate sooner and buy tires better for long wear with sufficient grip for your actual driving?
Hungryhawk is offline   Reply With QuoteReply With Quote
axle , rear , side , tire , wheels
Rear wheel out of alignment Haydenatx 5th gen T4Rs 19 07-13-2020 04:46 AM
Passenger rear wheel out of alignment?? richamc01 3rd gen T4Rs 20 08-09-2019 07:54 PM
2010 4Runner Rear Wheel Alignment Specs haikhanhjr 5th gen T4Rs 9 05-24-2013 12:12 PM
Rear Wheel Alignment <<<< 4th Gen T4Rs 2 01-23-2006 09:27 PM
This alignment shop is trying to tell me I need a 4 wheel alignment.... MudbogPete Maintenance/Detailing 6 12-20-2003 04:22 PM
