Old 05-08-2024, 10:40 AM #1
timbird1219's Avatar
timbird1219 timbird1219 is offline
Real Name: Tim
timbird1219 is on a distinguished road
Real Name: Tim
Strange static coming from dash on morning start up
I recently replaced my negative terminal connector and since on morning start ups I hear a static and my 03 t4r will have all gauges goto zero. No idea what’s causing this but this morning it happened and now my outside temperature and ac temperature is reading in Celsius and not Fahrenheit and my range is in km and not miles now. Does anyone know how to fix this? Or do I just need to get a new dash and crap.
timbird1219 is offline   Reply With QuoteReply With Quote
Old 05-08-2024, 01:33 PM #2
beautifulbrick beautifulbrick is offline
beautifulbrick is on a distinguished road
Changing Outside Temp from F to C On Display
Don't know if that's helpful or not as there doesn't seem to be a concrete answer. It seems towards the end of that thread there may be a ground that switches the display from miles/km and f/c. Perhaps this was triggered when you replaced the terminal?
Others seem to suggest disconnecting the battery for an hour can reset it?
Sounds like you may have a bad ground somewhere.
beautifulbrick is offline   Reply With QuoteReply With Quote
Old 05-08-2024, 03:29 PM #3
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb is a jewel in the rough ArthurKotb is a jewel in the rough ArthurKotb is a jewel in the rough
ArthurKotb's Avatar
Real Name: Rich
Sounds like a bad ground connection. Maybe there's an issue with the new clamp or even the other end of that cable. It's possibly corroded under the connector/washer/cable. That static noise is possibly arcing from the bad connection. Since you haven't done work on any of the other areas, that's where my suspicions would be. Check both ends of that cable and the new terminal.
BTW, you put grease only on the outside of the connectors, not between the battery terminal and new connector, right? No dielectric grease, right? :-)
Rich
2004 V8 4Runner 150K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 05-08-2024, 06:17 PM #4
Real Name: Tim
Real Name: Tim
So unhooking the battery for a hour seemed to do the trick with switching it back to Merican units but ya I’m gonna get a different connector because it probably is arcing a bit
Old 05-15-2024, 09:22 PM #5
Real Name: Tim
Real Name: Tim
So I replaced the clamp, didn’t change anything, replaced the ground cable to the battery, that kinda helped but not all the way. Btw I just had the engine replaced so maybe a ground isn’t on all the way. Does anyone know where all the ground locations are? It’s a V6 also
Old 05-15-2024, 09:24 PM #6
Real Name: Tim
Real Name: Tim
Old 05-16-2024, 10:34 AM #7
ArthurKotb's Avatar
Real Name: Rich
ArthurKotb's Avatar
Real Name: Rich
In my 2004 with V8 there's a "Y" connection on the negative post. One cable goes to the body, about 6" next to the negative post, then the other part of the cable goes into a bundle and down on the port/left side of the engine. If you have that short negative connection you should take the body bolt out and check underneath that connector for corrosion. It really sounds like a poor negative connection between the battery negative and the body. That's the one thing that's common to everything electrical in the car.
Rich
Kentucky
Old 05-17-2024, 11:48 PM #8
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
I'd recommend taking a look at the ground connections related to the new engine you installed. If swapping out the ground cable helped a bit, there might still be some resistance in the electrical path. Make sure those connections are clean and snug, and maybe use a multimeter to check for any voltage drop across them.
Since you're experiencing static and gauge fluctuations, inspect the wiring harnesses around the dash too.
Plus, I'd check the cluster itself for any faults or loose connections.
weberlukas74 is offline   Reply With QuoteReply With Quote
dash , morning , start , static , temperature
Static sound coming from speakers? Buba1 5th gen T4Rs 8 06-01-2024 10:27 AM
Strange electrical motor noise coming from dash clkcrawford 5th gen T4Rs 23 02-04-2023 04:13 PM
Strange noise coming from behind dash? (link with audio) uncleslam23 3rd gen T4Rs 3 02-24-2015 03:27 PM
1999 T4r fast clicking coming from under dash, no start tgaller 3rd gen T4Rs 3 04-15-2014 01:42 PM
Start up sound in the morning? Trdsupranick 4th Gen T4Rs 2 12-17-2008 03:30 AM
