Originally Posted by weberlukas74
1. Installing new upper control arms along with the front struts can improve handling and suspension performance, even if your current ones seem okay. It could make your driving experience smoother.
2. If you go for the 5th generation front coils and pair them with Bilstein 4600 rear shocks, it should make your ride better both on and off the road. They work well together to give you a balanced ride with improved comfort.
3. As for the stance, yes, the front might lift a little with the 5th gen coils, but it shouldn't tilt too much. However, exact changes can depend on load and driving conditions. But you can check the height after installing them to make sure it's how you want it.
Thanks. I need to figure out what a fair price would be for the complete front coils and upper control arms.
Also, I can't seem to find 4600s for the rear anywhere. Neither Amazon or Rock Auto seem to have them. Rock Auto only has 4600s for the front.
In regards to the rear suspension, I wonder if the rear springs themselves are compatible with the 4th gen? I am not going to mess with 5th gen rear shocks. I have no desire to grind and drill to make them fit.
