Old 05-17-2024, 08:35 PM #1
SocalSam SocalSam is offline
SocalSam will become famous soon enough
Old Question, New Owner: 13.2 or 12.6 Rotor Size?
I have 2003 Limited. Does this mean my rotors are 13.2"? Or is looking for the caliper cast number the best way? Found these posts on the web.
From experience up until now...
All 4runner than are sr5 have 12.8" front rotors
All sports trim and limited trim have 13.3" front rotors
The rear are the same for both.
Usually if you have x-reas suspensions it will most likely be 13.3"
Another way to tell is. If your vehicle came with 16" wheels it is 12.8"
And last but not least, check your Vin number with the dealer to have them tell you what size your rotor is.
On the inside of the OEM calipers there is a 13** model # that will indicate the proper size rotors for your 4Runner.
13WH- 13.3"/338mm rotor diameter
13WL- 12.6"/319mm rotor diameter
13WG- 12.6"/319mm rotor diameter
SocalSam is offline   Reply With QuoteReply With Quote
Old 05-17-2024, 08:46 PM #2
Real Name: Skip
Real Name: Skip
I found the best way to be sure which size you have is with a good old tape measure!
That's the way I checked mine because the calipers on mine had been replaced at some point with aftermarket calipers and they don't have casting numbers that match anything that's on OEM calipers.
2004 Limited V8
Old 05-17-2024, 08:50 PM #3
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I too, have an '03 Limited that I bought used about 10 years ago and when I went to service the brakes I found I had the smaller rotors on front to my surprise. I upgraded to the larger just because.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 05-17-2024, 08:55 PM #4
That would be definitive. I'm trying to brain power this one before going manual mode.
Old 05-17-2024, 08:57 PM #5
Yours is a V8 and should have the 13.2 rotors. I have V6. Does your build sheet show 12.6? Where can I find build sheet for mine?
Old 05-17-2024, 09:04 PM #6
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I never bothered to check into it. I had ordered Stop Tech rotors/large diameter, but when I went to install, the calipers wouldn't fit, so bought the correct NAPA calipers and proceeded.
Old 05-18-2024, 12:13 PM #7
I crawled under the truck without jacking (which is nice) and found 13WG calipers. I have 12.6" rotors. When I go to the junkyard, I will take a tape measure in case calipers are aftermarket with no stamping.
I'm sort of interested in the bigger brake swap but I don't have any complaints with what I have.
diameter , rotor , rotors , size , trim
Rotor size question HomerJay 4th Gen T4Rs 43 02-20-2021 01:20 PM
rotor size question thholr Maintenance/Detailing 9 07-03-2019 04:22 PM
Rotor size tecate1987 4th Gen T4Rs 3 10-22-2013 01:56 AM
New owner tire and rim size question Reese505 3rd gen T4Rs 13 05-09-2012 11:17 PM
Rotor size? wildcar 3rd gen T4Rs 3 01-25-2009 03:15 PM
