Old 05-19-2024, 03:32 PM #1
jacksheadache's Avatar
jacksheadache jacksheadache is offline
jacksheadache is on a distinguished road
tensioner puller removal help 4.7
Water pump and timing belt.. attempting to remove the tensioner pulley.
Have read this is reverse thread..
It's not moving with a compact impact wrench
This video makes it look like a dream: https://www.youtube.com/watch?si=qroWGKR162AAusTm&t=799&v=NUK2TLZqy0k&feature=youtu.be
07 Limited 4.7
90 Mustang GT 5.0
jacksheadache is offline   Reply With QuoteReply With Quote
Old 05-21-2024, 12:17 AM #2
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
Give it a good soak with some penetrating oil.
Or, maybe, try using a longer breaker bar for more power.
If that doesn't work, a bit of controlled heat from a torch can sometimes help to expand the metal and break the bond.
weberlukas74 is offline   Reply With QuoteReply With Quote
Old 05-21-2024, 12:44 AM #3
Real Name: Skip
Real Name: Skip
The bolt holding the tensioner to the engine is not reverse thread, it's a normal bolt..... however the bolt holding the actual "pulley" to the tensioner is a reverse thread bolt, this is the bolt going through the bearing of the pulley.
In the video if you watch closely you can see him "break" the bolt loose manually before pulling the trigger on the impact ratchet to remove the bolt and he turned it counterclockwise to break it loose.
2004 Limited V8
Old 05-24-2024, 05:27 AM #4
carypires carypires is offline
carypires is on a distinguished road
This video makes it look like a dream: https://www.youtube.com/watch?si=qroWGKR162AAusTm&t=799&v=NUK2TLZqy0k&feature=youtu.be slope
Great video! Would you recommend a reputable manufacturer replacement kit maker and reputable seller please. Thank you!
carypires is offline   Reply With QuoteReply With Quote
Old 05-26-2024, 02:29 PM #5
I appreciate the suggestions / advice. Was able to break it loose and then remove the bolt.
Finally making my way to put this thing back together and as careful as I've been, somehow misplaced one of the following stud bolts.. anyone have any idea what size/where I can pick up a new one?
https://imgur.com/eV8QbLj
https://imgur.com/HWNUvI8
Found a reference to #90116-06144 here Stud Bolt #90116-06144 | Autoparts.toyota.com - but not sure where I can pick a new one up..
07 Limited 4.7
90 Mustang GT 5.0
Old 05-26-2024, 03:40 PM #6
Real Name: Skip
Real Name: Skip
That's a very specialized bolt/stud you have misplaced, going to be very hard to find a new one, which would be only from the dealer.
If I were you I would either FIND that bolt/stud you lost or start searching salvage yards.
The only other suggestion would be find some metric threaded rod the correct thread, cut it too length and use a couple of nuts!
2004 Limited V8
Old 06-04-2024, 09:05 AM #7
Yeah I'm not entirely sure how that happened. After hours of looking through the garage for it and not finding it, I'm almost questioning if it was there to begin with.
I am going to start an individual post about the bolt in hopes someone can help identify it.
Thank you
07 Limited 4.7
90 Mustang GT 5.0
Old 06-04-2024, 04:18 PM #8
Real Name: Skip
Real Name: Skip
Thank you
Make sure you post measurements of the bolt, the more detailed the better.
2004 Limited V8
makes , reverse , tensioner , video , wrench
'11 rear hub puller rocjoc 5th gen T4Rs 0 07-05-2020 05:25 AM
TRD Dynamin Tensioner Removal clt750 3rd gen T4Rs 1 12-02-2019 08:32 PM
Tensioner pulley or tensioner assembly? T4R03 4th Gen T4Rs 3 03-07-2019 09:17 AM
YES! Timing Belt Tensioner Removal without removing AC Bracket BamaDrewski 3rd gen T4Rs 17 09-12-2018 07:39 PM
Timing Belt change- Tensioner and idler bearings? Hydraulic tensioner? DiskDoctr Maintenance/Detailing 10 09-13-2015 09:01 PM
