Old 05-24-2024, 04:43 PM #1
Tokylon's Avatar
Tokylon Tokylon is offline
Real Name: Todd
Tokylon is on a distinguished road
Tokylon's Avatar
Real Name: Todd
VSC/Trac issue
Hello,
I have the following conditions: vsctrac light on, check engine light on and blinking, car drives but bumps and bounces a lot. What does this indicate and how can I fix it? Thanks.
I have a 2005 SR5 with around 250,000 miles. Have never had any other real issues with it.
Thanks
Tokylon is offline   Reply With QuoteReply With Quote
Old 05-24-2024, 05:23 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
It started doing this out of the blue, or had you been working on your vehicle in any way?
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 05-24-2024, 07:50 PM #3
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
A blinking check engine light usually means a severe misfire that could damage your vehicle. Possibly a bad coil pack or multiple other items could so this. That would explain the "bumps and bounces". There should be at least one code stored, have it checked ASAP.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 05-26-2024, 12:30 AM #4
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
Start by checking fluid levels, especially in the transmission and differential.
As it was said before, a blinking check engine light is often a sign of misfires. I’d suggest checking spark plugs, ignition coils, and wires. They wear out over time, affecting your engine's performance and stability control.
Also, consider issues with the ABS or wheel speed sensor.
weberlukas74 is offline   Reply With QuoteReply With Quote
bumps , fix , light , lot , vsc/trac
HELP Please!! - Intermittent ABS/VSC/TRAC Light Issue 17TRDOffRoad Problems & Warranty Issues 8 07-29-2021 11:58 AM
Any long term issue with trac off? Sherminator866 4th Gen T4Rs 1 01-13-2015 08:40 PM
vsc off/trac issue JCDM 4th Gen T4Rs 3 10-20-2014 07:32 PM
Weird VSC/TRAC issue? T4RBoarder 3rd gen T4Rs 1 10-16-2014 02:02 PM
03 VSC / TRAC Issue - Help Needed rcargs96 Problems & Warranty Issues 1 01-11-2009 10:32 AM
