Old 05-29-2024, 10:00 AM #1
Monty87ls Monty87ls is offline
Monty87ls is on a distinguished road
Temp gauge not accurate?
Hello all I'm having some issues lately with the temp gauge i think? While back noticed the gauge wouldn't go above the halfway point to where it should go so I quickly ordered a OEM thermostat from amazon to see if that was the issue. Seems its not.. The other day the gauge wouldn't read above cold after driving for over an hour!
Maybe the gauge is having issues? Maybe the temp sensor is bad? I'm considering just putting a temp sensor in to see if it helps but figured id check if anyone else has experienced this! Thanks for your help!
Monty87ls is offline   Reply With QuoteReply With Quote
Old 05-29-2024, 10:25 AM #2
SocalSam SocalSam is offline
SocalSam will become famous soon enough SocalSam will become famous soon enough
If coolant level was low enough to uncover temp sensor, it would read cold. If your thermostat was stuck, engine would overheat. That's not the problem. Either it is temp sensor, temp sensor wiring, or instrument cluster causing problem.
SocalSam is offline   Reply With QuoteReply With Quote
Old 05-30-2024, 05:10 PM #3
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
I think you can unplug the sensor to see what the gauge will do and maybe short the two connector pins to get the full range. That would verify the wiring and cluster but will probably set a code. I'm unsure what the range of these sensors are resistance wise and didn't find much gen specific on google. Could put it in the freezer, ohm it out and then warm it in water to check it.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 05-31-2024, 10:24 AM #4
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
Have you noticed any other issues, like overheating or odd engine behavior?
Before installing a new temp sensor, check the wiring and connections.
And maybe, also look for leaks, ensure the radiator and coolant reservoir are filled to the correct levels, and check the cooling fans. Plus, verify if there's no air trapped in the cooling system.
weberlukas74 is offline   Reply With QuoteReply With Quote
gauge , hour , issues , sensor , temp
Need An Accurate Tire Pressure Gauge Rick G. General Discussions 12 03-16-2024 12:39 PM
Gas gauge not accurate?? kenlainpro_ 4th Gen T4Rs 6 04-19-2023 01:16 PM
How accurate are our temp gauges? solsnowbarger 3rd gen T4Rs 19 10-15-2015 02:47 PM
2001 SR5 2WD - Bubbles in Tach gauge and Temp gauge tenro1 3rd gen T4Rs 7 01-01-2014 07:07 PM
Tach, Fuel Gauge, Temp Gauge, Oil Pressure Gauge, Alternator Quit Working silentrunner Classic T4Rs 3 10-05-2013 12:51 PM
