Old 05-30-2024, 10:45 PM #1
Venz Venz is offline
Real Name: Andrew
Venz is on a distinguished road
Real Name: Andrew
Rear hatch stuck
Hi all
My rear hatch is stuck closed. The actuator makes a noise when you click the button but instead of opening it makes a noise again after a few seconds to reclose. I took the plastic interior and vapor barrier off and tried pulling up on the two levers on the actuator manually as some suggest, no luck, damaged my finger pulling so hard. I suspect the culprit is rust but I need to get the door open to take the actuator out and clean it out with penetrant. I sprayed around where I could from the inside with the door closed, maybe it will loosen up overnight.
How else can I get the door open?
Thanks
Venz is offline   Reply With QuoteReply With Quote
Old 05-31-2024, 09:59 AM #2
Ralph Blake Ralph Blake is offline
Ralph Blake is on a distinguished road
Originally Posted by Venz View Post
Hi all
Thanks
Here is a list of videos that might help you.
https://www.youtube.com/watch?v=moJ2Qg24mDo
Ralph Blake is offline   Reply With QuoteReply With Quote
Old 05-31-2024, 10:14 AM #3
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
Maybe, also you could apply penetrating oil directly on the latch from both sides of the hatch. Leave it for a while to break up any rust or dirt.
Or, try warming up the latch with a hairdryer or heat gun.
weberlukas74 is offline   Reply With QuoteReply With Quote
Old 05-31-2024, 05:49 PM #4
SocalSam SocalSam is offline
SocalSam will become famous soon enough
You have a corroded catch ring which is not releasing latch actuator. Easy fix. Take interior plastic panel off and manually release actuator. Remove catch ring and flip it around to present the clean side to the actuator.
SocalSam is offline   Reply With QuoteReply With Quote
Old 05-31-2024, 08:33 PM #5
Real Name: Andrew
Real Name: Andrew
How does one 'manually release actuator'? I tried pulling up on the two levers with my hand and ripped my finger open pulling so hard before anything moved. Is there another way?
Thanks
Old 05-31-2024, 10:14 PM #6
Thanks
Pull up on smaller lever. Have an assistant push hatch in from the outside to release tension on the latch.
Old 05-31-2024, 11:57 PM #7
Real Name: Andrew
Real Name: Andrew
No luck
Old 06-01-2024, 02:08 AM #8
No luck
Not good. Try spraying WD40 with the straw where the latch jaws clamp the catch. Use a claw hammer claw or similar to apply force to the smaller lever. Unfortunately, this may damage the actuator so try at your own risk.
Old 06-02-2024, 08:42 AM #9
adammsu adammsu is offline
adammsu is on a distinguished road
i had to push DOWN the big lever, and then UP the smaller lever to get mine to manually release
Adam
06 Sport, v6, 4wd
sold years ago, still kicking myself: 97 SR5., 3.4L, 5spd, 4X4
adammsu is offline   Reply With QuoteReply With Quote
Old 06-02-2024, 02:18 PM #10
rumfoord's Avatar
rumfoord rumfoord is offline
rumfoord is on a distinguished road
rumfoord's Avatar
I had a similar issue and had to tie the lever in the open position then sat down in the back and kicked the door open from the inside.
rumfoord is offline   Reply With QuoteReply With Quote
actuator , door , hatch , open , rear
Rear hatch is stuck closed TucsonMike 3rd gen T4Rs 4 05-31-2021 09:09 AM
Stuck rear hatch 4RunnerChaos 3rd gen T4Rs 2 05-28-2015 02:48 PM
rear hatch stuck is stuck tried everything.. tristentrd28 3rd gen T4Rs 4 11-09-2014 12:45 PM
Stuck rear hatch door bek3k 3rd gen T4Rs 5 09-02-2014 08:45 PM
Disassembling Rear Hatch -> Stuck Rear Window MunkeyTX 3rd gen T4Rs 1 09-02-2008 10:48 PM
