Old 06-02-2024, 08:21 AM #1
adammsu adammsu is offline
adammsu is on a distinguished road
Rear hatch actuator fix - latch closes, waits 2 sec, finishes cycle and won't open
So my hatch popped open the other day. i closed it, then got home and it wouldn't open again, no noise or nothing. i reset the ECU-B fuse, which got it to open, but then the same again (close but not open). The main difference i noticed was that the cycle took longer.... after getting it open, i closed it, it would latch, sit for 2 seconds, and then finish the cycle - and THEN the button wouldn't work... Anyway, i figured it out and thought i would share.
after taking it out and playing with it for a while, i found it wasn't mechanical at all. i PB blastered, greased, all did nothing. it turn out to be a "sensor" issue.
In my case, since the motor was fine, i didn't think it was mechanical. i put it in the car without the door cover and watched. it dawned on me that the actuator was moving, but then sitting for like 2 seconds before finishing the cycle. The actuator didn't know where it was and therefore timed out (thus the 2 second delay - also the motor was hot because it was trying to push and couldn't). it became obvious that the motor is pushing the lock to one side, and not knowing when to stop.
Rear hatch actuator fix - latch closes, waits 2 sec, finishes cycle and won't open-pic1-jpg
this would cause the controller to freak out and disable it, thus requiring the reset to get it to open
turns out the positional sensor was gummed up. i didn't get a picture, but you can disconnect the white sensor with 2 screws.
Rear hatch actuator fix - latch closes, waits 2 sec, finishes cycle and won't open-pic2-jpg
then, you will see a part that rotates and has 2 prongs, like a fork. if you take a flat head screw driver, you can gently pop open the rotating part, essentially separating the "fork part" from the housing. i did 2 things: i took a needle and pried up the pins just a little to make sure they make contact, and i took a q-tip and cleaned out inside the sensor. it was all grimy and wet in mine, not sure how it got there, but i cleaned it out.
then i reinstalled, closed the door, lock and unlock, and it was perfect after that.
hopefully this helps someone, let me know if you have questions.
Adam
06 Sport, v6, 4wd
sold years ago, still kicking myself: 97 SR5., 3.4L, 5spd, 4X4
adammsu is offline   Reply With QuoteReply With Quote
Old 06-03-2024, 12:31 PM #2
SocalSam SocalSam is offline
SocalSam will become famous soon enough
Very helpful, thanks. The gummy stuff is likely amber grease that carmakers put on plastic gears which hardens over time. Ford uses this stuff which gums up blend door actuator. BDA in a Ford is a PIA to replace.
SocalSam is offline   Reply With QuoteReply With Quote
Old 06-11-2024, 09:30 AM #3
alia176 alia176 is offline
alia176 has a spectacular aura about alia176 has a spectacular aura about
Attachment 411648
Attachment 411649
Excellent writeup, thank you!!!
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
cycle , motor , open , part , sensor
How to open the rear Hatch and fix the Actuator 4th gen 4runner mastee 4th Gen T4Rs 3 06-05-2024 04:39 PM
4th Gen 4Runner Tail Gate Latch Hatch Actuator Replacement DCameraMan 4th Gen T4Rs 0 05-17-2023 06:03 PM
DIY Fix - Rear Hatch Won't Open But Actuator Works justinfetalvero 4th Gen T4Rs 7 01-20-2022 08:05 AM
Rear hatch will not open (not latch related) Steve240 3rd gen T4Rs 5 09-14-2012 09:29 AM
How to dissconnect electricity to rear hatch open/actuator use MICA4R 4th Gen T4Rs 6 07-15-2011 06:01 PM
