06-08-2024, 10:38 PM
Won't start | Electronic tripping somewhere
Hey there,
I have a 2004 V8 4Runner that I need help getting on the road again. I drove the truck all day today with no issues. I get home after errands and go to start the truck about an hour later and nothing. No clicking, no lights, nothing. However, I notice that when I put the key in ACC lights come on (very faintly), but when I put it into the ON position everything goes blank.
Took the terminals off and cleaned them. Nothing. Eventually the truck gained a little more power and I was able to track down crazy noises coming from the engine bay. Pulled out fuses until I heard silence. Which ended up being the big pink and blue relay labeled TRC MTR and ABS MTR. Not sure how this all relates which is why I am here...
I had the fuses out and wanted to see if the truck could gain power again and potentially get it to start and cross off the relays as the problem. However, while waiting the truck started flashing lights in the dash and the horn was clicking/honking very faintly repeatedly. I have no idea what is going on and don't even know where to begin. Any insight or help is greatly appreciated!
2004 SR5 V8 (Betty White) | 5100's | Toytec Front Coils | Toytec SuperFlex Rear | Spidertrax | Limited Wheels | 275/70/18
06-09-2024, 04:06 AM
First Step - have the battery tested, AutoZone/Advance Auto will do it for free.
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
06-09-2024, 08:55 AM
^^This.
Second step - check/replace alternator brushes.
06-09-2024, 09:33 AM
I agree with this. Low voltage makes everything go a bit haywire. The days of it just making the starter relay make a strange buzzing noise are long gone.
Don't forget it could also be an unstable voltage, again a new/tested battery will help rule this out.
2008 2.7 2WD 4 speed (Tacoma-Runner?)
06-09-2024, 10:42 AM
Pink and blue relays are for the brake booster pump.
06-09-2024, 11:23 AM
Which is why all of this is so puzzling to me.
06-09-2024, 11:25 AM
Took the battery to Autozone this morning. Battery was toast. Could tell is was going to be the culprit once I got the battery retaining bolts off and there was corrosion.
Getting a new one put in after I install a new PS pump. Will come back with updates afterwards.
06-09-2024, 11:26 AM
Like stated above^ Took the battery to get tested and it was donezo.
Installing a new PS pump today anyways, so once it's put together I'll come back with updates. Still puzzled that the battery would through all the relays and electronics for a loop. But I guess I'll know the answer once a new battery is installed.
06-09-2024, 12:29 PM
Real Name: Skip
Real Name: Skip
With the electronics in vehicles today low voltage make them do very strange, abnormal and unexpected things that they would not normally do!!
It's not like a electric motor that will just run slower or not work at all.
That's why when strange electrical things start happening, the first things to check is battery and it's connections, then alternator, then fuses in that order.
2004 Limited V8
06-09-2024, 03:11 PM
Relays are likely not receiving enough voltage so failures will seem random. Anyways, you found the issue. Recommend you get a $10 DVM from Harbor or Amazon so you can measure voltage yourself.
06-10-2024, 02:06 PM
PS Pump installed and bled. New battery installed.
Seems to be all good again. Thanks for info everyone!
06-11-2024, 03:11 PM
Curious as to why a new PS pump was needed? Was yours groaning or something?
As stated above, I'd purchase a DVM (digital volt meter) to leave in the vehicle for any future troubleshooting on your or someone else's ride.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
06-11-2024, 05:09 PM
I added a dual USB port connector that also happens to have a voltage gauge. Very nice to see what's going on with the charging system.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
06-12-2024, 05:06 PM
Got pics of that?
2009 SR5 - Former Hertz rental - added roof rack and stock hitch reciever
06-13-2024, 11:21 PM
Originally Posted by Bigcee
Got pics of that?
Sure. I removed the lower useless door on the center dash to ft my backup camera. I had extra space so glued a piece of plastic in place for one of these to fit in. Not great looking but super useful. Please ignore the dust.
Amazon.com
Mike
03 4runner Limited
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
