Old 06-09-2024, 08:22 PM #1
jacksheadache's Avatar
jacksheadache jacksheadache is offline
jacksheadache is on a distinguished road
Timing belt replacement (V8)
In the process of putting this thing back together after a water pump and timing belt replacement.
Before I proceed with the new timing belt install, will someone provide some clarity on this?
I've found various YouTube videos and have followed them during the removal of the original parts and have found conflicting suggestions for the install. Top dead? just beyond?
Here's where it currently sits..
Crank:
https://imgur.com/v9N9rKU
Driver side cam (I'm not entirely sure where the mark on this one even is):
https://imgur.com/JcyEcAW
Passenger side cam:
https://imgur.com/aCJcLE7
Thank you so much
07 Limited 4.7
90 Mustang GT 5.0
jacksheadache is offline   Reply With QuoteReply With Quote
Old 06-14-2024, 03:46 PM #2
bump.
Just want to make sure this is correct before putting it back together and causing an unnecessary explosion. 💥
Thanks
07 Limited 4.7
90 Mustang GT 5.0
Old 06-14-2024, 05:00 PM #3
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
You probably know more than most that are seeing this. I'd verify with some YT videos and if all good, hand turn it a few rotations to make sure nothing is hitting and all lines back up. If memory serves me, I think the cams should line up every other revolution of the crank. It's been many moons since I've done a TB. All my current vehicles have chains.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 06-16-2024, 04:12 PM #4
jreask's Avatar
jreask jreask is offline
jreask is on a distinguished road
jreask's Avatar
I just did my 2008 V8. I lined up the crank on the oil pump dot, put both cams on the timing marks, not the Tís. It fires right up. As long as your belt marks align correctly on the crank and cam marks, you are golden. I canít get any pics to load or I would show you pics.
jreask is offline   Reply With QuoteReply With Quote
Old 06-16-2024, 04:20 PM #5
jreask's Avatar
jreask's Avatar
https://www.toyota-4runner.org/attac...1&d=1718569206
Timing belt replacement (V8)-img_1136-jpg
Old 06-16-2024, 04:33 PM #6
jreask's Avatar
jreask's Avatar
I think the driver side cam mark is over to the left of the cam. Maybe 40 degrees off? It’s hard to see if that’s it or not. If so, turn it to the mark.
Old 06-17-2024, 03:19 PM #7
Thank you for the replies. I'll give this a go at some point this week and cross my fingers.
07 Limited 4.7
90 Mustang GT 5.0
Old 06-18-2024, 04:34 PM #8
alia176 alia176 is offline
alia176 has a spectacular aura about alia176 has a spectacular aura about
This is huge, do NOT use the Ts for the belt, ask me how I know!!! I did this on both cam sprockets, and the engine ran but ran like poop. Took everything apart and followed the FSM AGAIN, but this time, I did it correctly!!!
Timing belt replacement (V8)-20170311_124739-jpg
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 06-23-2024, 12:27 PM #9
parsky1 parsky1 is offline
parsky1 is on a distinguished road
What marks did you end up using? The notes in the fsm to go past TDC always confused me. It just seems overly complicated. Seems to me just go to TDC, Put paint marks on old belt, cams and crank. Transfer marks from old belt to new belt unless it has marks. Line up marks from new belt to marks on cams and crank. Also make sure factory marks for TDC still line up on crank and CAMs with your paint marks. Make sure all slack is on tensioner side and the pull the pin. Am I wrong?
parsky1 is offline   Reply With QuoteReply With Quote
Old 06-23-2024, 02:57 PM #10
Thanks again for all of the help here. Before I pull the pin.. will someone sanity check this?
So I have the two cams lined up with the markers on the belt.
To line up the belt with the crank, I had to rotate it slightly (a few teeth) according to this: https://youtu.be/HPpzLJwoxng?si=JYiZcV2ybxBq-D-i&t=314
From the crank top down view, clearly the marks for TDC are no longer aligned and I guess my question at this point is.. is that okay? If I'm understanding the replies here correctly, as long as the 3 points on the belt all align we're in good shape?
https://imgur.com/a/jcXTrA8
07 Limited 4.7
90 Mustang GT 5.0
Old 06-23-2024, 11:02 PM #11
This guy has one of the best explanations for the T marks: Toyota 2UZ-FE Timing Belt Marks 4.7L | TOYO Headquarters
belt , cam , found , side , timing
3rd Gen Timing Marks for Timing Belt Replacement FTW1996 3rd gen T4Rs 4 10-01-2015 04:00 PM
Timing belt replacement - V8 (2UZ) bergs 4th Gen T4Rs 5 05-30-2012 09:32 PM
Timing Belt Replacement Marty 3rd gen T4Rs 9 04-19-2012 04:12 PM
DIY Timing belt replacement?? txzaphod 3rd gen T4Rs 5 08-14-2008 01:41 AM
03 V8 Timing Belt replacement plus??? dweyer Maintenance/Detailing 2 06-20-2008 07:18 PM
