Old 06-12-2024, 01:45 AM #1
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Chain rattle on startup
240,000 2005 v6.
Just recently on about 3 of 5 cold starts I get a chain rattle for a split second. Once started once, it is fine.
Almost as if the timing tensioner stopped catching the ratchet to keep full tension and it relies on the oil pressure on startup.
Any ideas?
gaber6 is offline   Reply With QuoteReply With Quote
Old 06-12-2024, 05:02 PM #2
Bigcee Bigcee is offline
Bigcee is on a distinguished road
Hmmm, anyway to inspect the tensioner? I'm not familiar with the process.
2009 SR5 - Former Hertz rental - added roof rack and stock hitch reciever
Bigcee is offline   Reply With QuoteReply With Quote
Old 06-14-2024, 03:33 AM #3
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
There are three chain tensioners, one on each chain. You'd need to use a stethoscope in order to find the noisemaker. The main chain tensioner uses a ratchet as you mentioned, but the #2 chain tensioners do not.
I've had oil filters with (suspected) defective anti-drainback valves cause noisy cold starts. Likely the #2 tensioner(s) but I didn't dig in to locate the source, just changed the oil filter and added oil to top off. Noise gone.
So...what oil filter and oil are you running?
waypoint is offline   Reply With QuoteReply With Quote
Old 06-14-2024, 12:02 PM #4
Probably does need an oil change but I usually just add a quart as it needs it.
Of course the past 3 starts it has been quiet.
The chain guides are all new from my head gasket rebuild but I kept the old chain and tensioner.. it does seem like maybe the ratchet could have stuck. I'll consider the oil filter, too. I think I have a mobile 1 filter on there
catching , chain , rattle , startup , timing
chain, tin can rattle BetterontheMtn 3rd gen T4Rs 2 04-02-2024 07:23 PM
rattle in the vents, sputters on startup Snarf 3rd gen T4Rs 0 10-10-2014 11:55 AM
Help! rattle noise startup & idle scrapper 3rd gen T4Rs 3 12-07-2012 08:11 PM
Diagnosis Challenge - Rattle - Timing Chain, Valves?? creyb Classic T4Rs 2 04-06-2011 01:42 PM
Snow cable Security Chain Company ZT729 Super Z LT Light Truck and SUV Traction chain Christian Classifieds - buy & sell (no commercial ads please) 0 04-29-2010 06:28 PM
