Originally Posted by Bravo Kilo
Thanks for the reply! Thats what I'm thinking happened. Where is the ABS control module located in a 2008 4Runner?
I guess it couldn't be the ABS control module because now that my brain is working correctly the ABS control module I believe is mounted on the side of the master cylinder under the hood.
That being said there are several other control modules under the dash on both the driver's and passenger's side that could possibly affect the ABS system and or throw some of the codes you have, if I were you I would take it back to whoever replaced the heater core and have them fix the issue you now have but didn't have before they did the work!!
