Old 06-19-2024, 10:32 PM #1
runnyrunnerton's Avatar
runnyrunnerton runnyrunnerton is offline
runnyrunnerton is on a distinguished road
Cool Chasing crank no start please help
4th gen is my brothers. Iím a 3rd gen guy. He parked it at my house. I cranked it drove it around, sat for 5 days refused to start, battery died, charged battery overnight crank and drove it next to my barn. Note when it ran it ran fine, smooth no issues. Parked by barn and there it sits. Refusing to start. New fuel pump as we suspected no fuel, crank no start. Checked coil packs,(recently replaced, mechanic said the plugs were fouling out and ruining the packs? My brother is not mechanically inclined) coil packs didnít produce much spark, ohmed out can sensors found a bad one, replaced. Crank no start. No spark. Swapped crank sensor. Crank no start. Canít check for spark without buddy. Moved around relays at random, they all cycle when touched to 12v and all the fuses under the hood checked good. Crank no start. Engine responds to a little ether, but just enough to cough and die. Whatís next? Any help appreciated? Donít get no spark with new coil packs, plugs looked decent.
97 Limited 4x4 218,000 3.4 V6 4.88's E-Locker, Arb Locker 295/70r17 Nitto Trail Grapplers, Custom rear bumper, 06 Sequioa Wheels, Toytec Ultimate 3.5 Lift OME 891's Bilstein 5150's 4crawler 1.5" body lift, Spider Trac 1.25 spacers,ODL bumper, PIAA 520 and 510 SMR's, Taco Whip Mod,Pioneer Head Unit, Satoshsi grille
My Build Thread
runnyrunnerton is offline   Reply With QuoteReply With Quote
Old 06-19-2024, 11:05 PM #2
Buckaroo's Avatar
Buckaroo Buckaroo is offline
Buckaroo will become famous soon enough
Buckaroo's Avatar
If you are getting a sputter with the ether, sounds like you are getting spark but no fuel. Do the plugs look dry after trying to start it? They would be wet if fuel was getting to them I would look at that fuel pump that was replaced, relay and EFI fuse. I would think you ought to hear a bit of a hum when you key on before starting as the fuel pump kicks on and builds pressure - might try listening with ear to the fuel tank door. This is coming from general experience, not specifically 4th gen. All I got at the moment.
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
Buckaroo is offline   Reply With QuoteReply With Quote
Old 06-20-2024, 11:14 AM #3
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
I would disconnect the battery for 15 mins then try again and see if any codes are stored.
Also check the battery is giving a steady 12.5V or so and the terminals are tight.
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
Old 06-25-2024, 11:11 PM #4
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
You need to verify fuel pressure or at least listen for pump noise.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 06-28-2024, 09:19 AM #5
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
Any aftermarket alarm install?
Just hit the unlock button twice and see if it cranks again. Maybe it got a starter kill relay wired up from the aftermarket system.
Also, any gas in the tank?
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
coil , crank , packs , spark , start
No start no crank sugjavier 3rd gen T4Rs 24 12-28-2022 06:00 PM
Crank no start no check engine light no tach bounce on crank [email protected] 3rd gen T4Rs 11 08-29-2022 04:36 PM
Crank, no start OLD BOB 4th Gen T4Rs 1 04-11-2022 09:39 AM
Crank no start thecole1098 3rd gen T4Rs 10 07-21-2018 07:44 AM
3RZ Crank, No Start Red October 3rd gen T4Rs 4 08-13-2016 03:51 PM
