Old 06-30-2024, 12:35 AM #1
johnpinetree johnpinetree is offline
johnpinetree is on a distinguished road
steering wheel shimmy when I get on the brakes
Wits end over here. I've replaced damn near all of the front suspension components with OEM stuff:
Lower control arms
Inner and outer tie rods
Shocks
strut mounts
sway bar bushings
One of the upper control arms maybe 5 years ago
Rotated tires
Shimmy is still there! Only happens when you're at highway speeds. If you get on the brakes and then enter a turn the shimmy does go away.
Thoughts? I'm about to replace my front calipers and get the rotors turned but figured I'd ask the community before blindly dumping more cash into this.
johnpinetree is offline   Reply With QuoteReply With Quote
Old 06-30-2024, 01:54 AM #2
stevelikesrhino stevelikesrhino is offline
stevelikesrhino is on a distinguished road
It's almost ALWAYS warped rotor.
stevelikesrhino is offline   Reply With QuoteReply With Quote
Old 06-30-2024, 05:31 AM #3
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
Yeah, I had this when I picked up my new (To me) 4Runner. Around town it was fine but juddered badly under braking on the motorway. The discs were corroded a little and had some contamination possibly from prolonged pad contact. I don't know for sure if they were even warped. It felt like something major at 70mph but that's all it was.
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
Old 06-30-2024, 08:32 AM #4
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
I've read several articles that explain rotor warp vs brake pad material buildup on rotors. According to those, rotors rarely warp because they're typically not subjected to enough heat to distort them. I think they actually need to glow red for that to happen. More often it's uneven buildup of pad material on rotors due to improper bedding.
thennen is offline   Reply With QuoteReply With Quote
Old 07-01-2024, 03:36 PM #5
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
I'd look at your upper control arms. Is the OEM original worn? Was your replacement OEM?
My JBA UCAs were worn and causing the exact symptoms you described. Went away with new bushings + ball joints.
'08 Silver SR5 V6 4x4: OEM+
Berty_K is offline   Reply With QuoteReply With Quote
Old 07-01-2024, 04:22 PM #6
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
This. You can often make it go away temporarily by sanding the rotors by hand on both sides. The fix to limit from happening is to bed new brakes in properly and in a hard stop try to limit the pads from sitting in one spot. It's now a habit for me to creep slightly after a hard stop.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 07-01-2024, 11:24 PM #7
Flooder305 Flooder305 is offline
Flooder305 is on a distinguished road
Had this, replaced my calipers, and rotors and the shimmy went away. There are many threads on how one puck of the rotors freezes up and creates this condition... It's so prevalent in the Midwest that guys buy the Napa Calipers with the lifetime guarantee and change them out almost once a year to prevent the warped rotor...
2005 V6 Limited 2WD
Flooder305 is offline   Reply With QuoteReply With Quote
Old 07-03-2024, 11:06 AM #8
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Rotors can warp without getting that hot if they are splashed with water -- going though a puddle. I've had that happen numerous times.
Another thing, though rare: I had a car once with the vibration from braking. Turned out to be a casting flaw in the rotor. For some reason there was a spot in the casting that was harder than the rest of the rotor, thus when the rotors wore, the hard spot did not wear as much, thus was higher than the surrounding surfaces. IT WAS NOT a pad material build up.
fkheath is offline   Reply With QuoteReply With Quote
Old 07-08-2024, 08:53 AM #9
OopsIBrokeIt OopsIBrokeIt is offline
OopsIBrokeIt will become famous soon enough
As others have said, the brakes are a common issue on these and will lead to vibration.
The thing almost everyone missed though, is that wheel bearings can also cause vibration under braking. I have fairly fresh 5th gen brakes all around and still had a minor vibration/shimmy when braking hard. Finally did the front wheel bearings a little while back and while they weren't totally trashed I could clearly see some signs of wear. That totally fixed the vibration issue and it's been nice and smooth since.
OopsIBrokeIt is offline   Reply With QuoteReply With Quote
arms , brakes , control , front , shimmy
Steering wheel shimmy FIX thegame7 4th Gen T4Rs 1 08-23-2019 04:44 PM
Steering Wheel Shimmy Samm25 4th Gen T4Rs 4 06-20-2018 05:20 PM
Steering Wheel Shimmy wakeboardwhan 4th Gen T4Rs 18 11-29-2011 07:33 PM
Steering wheel shimmy turkeyman 3rd gen T4Rs 20 08-26-2011 04:43 PM
shimmy in steering wheel??? kennyb3030 3rd gen T4Rs 4 03-09-2008 04:06 PM
