Old 07-04-2024, 07:54 PM #1
Jeffm65's Avatar
Jeffm65 Jeffm65 is offline
Jeffm65 is on a distinguished road
Jeffm65's Avatar
Parking brake light, the 3 yellow 4WD lights come on but no codes are generated
My 2006 4Runner, 6 cylinder, TR5, 4WD has been showing the red parking brake light on the left and the 3 yellow 4WD lights on the right have been coming on.
What I’ve noticed they come on when the engine and or the outside air is somewhat cold. When the temperatures change and things warm up the lights go out.
I checked for codes being flagged and there are none. I replaced the parking brake switch as suggested and that didn’t make a difference. I replaced the gas cap twice, still lighting up.
It seems to be outside or engine temperature related but don’t know which. The engine temperature is fine.
Any thoughts or ideas besides a sledge hammer would be much appreciated! I love this thing!!!
Jeff
Jeffm65 is offline   Reply With QuoteReply With Quote
Old 07-20-2024, 04:07 PM #2
Jeffm65's Avatar
Jeffm65's Avatar
Issues fixed
I fixed my issues finally. They lights all came on because the brake reservoir was close to empty. $10 later and everything is fine!
KJ6RHF
Old 07-20-2024, 05:30 PM #3
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
If your reservoir was very low like you say you need to check for leaks!!
Brake fluid doesn't evaporate the fluid has to be going somewhere, it either a leak or your brake pads are completely worn out and need replacing, as the pads wear out the pistons in the calipers move out and there's more fluid in the calipers and less in the reservoir.
2004 Limited V8
4wd , brake , engine , lights , parking
2008 4Runner Parking Brake Warning Light & ABS Light Flicker Simultaneously sant6236 4th Gen T4Rs 55 07-15-2023 03:34 PM
Parking Brake light, VSC/ Trac OFF - No codes Syr4RinNC 4th Gen T4Rs 2 02-02-2022 10:19 AM
2002 with Brake!, VSC OFF, VSC TRAC, and ABS lights on, no CEL codes Dragon_EX 3rd gen T4Rs 10 09-07-2021 11:18 PM
Brake lights on when I turn the parking lights on. mikey's2010SR5 5th gen T4Rs 9 03-09-2019 12:45 AM
led yellow front parking lights (in headlight housing) doodledo824 4th Gen T4Rs 2 01-28-2010 07:00 PM
