Old 07-05-2024, 01:14 PM #1
CO4x499 CO4x499 is offline
CO4x499 is on a distinguished road
Cats are showing higher temperatures at the inlet than at the outlet. Bad cats?
Like the title says. I swapped my battery and it started throwing these codes:
P0171 -System too Lean (A/F Lean, Bank 1)
Secondary DTCs-
P0101 - Mass or Volume Air Flow Circuit Range/Performance
P0138 - Oxygen Sensor Circuit High Voltage Bank 1 Sensor 2
I replaced the MAF, PCV, cleaned the intake throttle body. The mechanic said I need to replace my front/back O2 sensors and that my cats were fine. I live in CO so I need them to pass emissions (year away).
CO4x499 is offline   Reply With QuoteReply With Quote
Old 07-05-2024, 06:27 PM #2
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Secondary DTCs-
Listen to your mechanic and replace the O2 sensors before assuming it's the cats.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 07-06-2024, 12:56 AM #3
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Cool
A slight leak on the exhaust gasket may also throw an emission code. I bought all new stuff as it was old but once I had the right manifold on, I realized how bad the donuts were and only replaced the left donut and all was fixed. Now I have a spare oem and spare new replacement set of manifolds with the cats
gaber6 is offline   Reply With QuoteReply With Quote
bank , cats , circuit , lean , sensor
4.0 V6 Removing Main Cats and Secondary Cats Stunna1019 4th Gen T4Rs 14 12-04-2022 12:25 PM
When V8 Cats go bad? TeryT 4th Gen T4Rs 37 12-21-2018 09:26 PM
04 Cats TankTop 4th Gen T4Rs 1 03-30-2015 03:01 PM
00 needs new cats... help? DanRC30 3rd gen T4Rs 24 01-29-2010 12:44 PM
Hi flo vs. OEM cats 3rdGENrunner Maintenance/Detailing 0 01-17-2006 01:04 PM
