Old 07-28-2024, 06:16 PM #1
mustbeme mustbeme is offline
mustbeme is on a distinguished road
Ignition EFI relay wont start thread Help please
Just installed a new battery. Old battery looked old from prev owner and gave out after some ignition symptoms. Now New battery and:
1) Nothing in holding run position no noise buzz nothing
2) then starter will engage and I can let go of key and starter keeps going
3) Engine will crank and run but after shut off I must pull the EFI relay to attempt a restart almost like "resetting" something
4) Some buzzing from Throttle body area, I can pull plug there or pull the EFI relay and make this stop
I have swapped the EFI relay with others and same result. Is there some other ignition component to check?
mustbeme is offline   Reply With QuoteReply With Quote
Old 07-29-2024, 12:28 AM #2
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
any aftermarket stuff installed? sounds like an aftermarket alarm, starter kill installed, maybe your key is not being recgonized by the transponder.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 07-31-2024, 04:04 PM #3
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
Any odd lights on the dash? As mentioned, immobilizer may be stopping it. I think there's a light that goes off after a short bit if the key is recognized but I'd have to look to see which it is.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 08-03-2024, 09:48 PM #4
Update: TPS/throttle body is continuously making noise and killed the battery overnight.
Getting TPS code in scan tool. I can pull the blue relay (EFI) under the hood and she usually fires right up. I ordered a replacement TPS/throttle body
I cleaned grounds, pulled fuses and clean and inspected. Hoping a bad TPS. I have not bench tested it. Don't have a manual. Thanks for the replies. Will update what I find out.
battery , efi , ignition , pull , relay
Why don't I have an ignition relay? Pale Rider 4th Gen T4Rs 2 02-04-2023 12:19 PM
Ignition hot relay connection Grgg1978 3rd gen T4Rs 10 08-31-2017 02:59 AM
Wont start after ignition on for 15 minutes ahhweewee Problems & Warranty Issues 1 10-08-2016 12:12 PM
92 replaced ignition switch now it wont start monte75020 Classic T4Rs 1 03-16-2013 07:50 PM
92 Four Runner Wont dies and wont start floridaboy6802 Problems & Warranty Issues 0 08-04-2010 10:24 PM
