Originally Posted by rdruss
Forget that. Bleed the rears by turning the key on and open the bleeder screw and it will pump a steady stream, couple of times and you're good. Then bleed the front using the standard push/hold/bleed with key off, or get a Mighty Vac and bleed fronts that way. I always crack the bleeder screw after a caliper replacement and wait until it gravity bleeds and then start the procedure. Never had a problem and my brakes are solid.
I did that when I installed the new calipers, but the brakes are still a little spongy. Not any worse than before, at least. And it definitely stops faster. Maybe I'm just overthinking this.
Originally Posted by SocalSam
Air gets trapped in the lines to the MC/ABS valve block. Have assistant press brake pedal and crack the lines. Also find a wet road with plenty of room and trigger ABS/TC events to get the fluid in the valve block moving. Repeat as necessary.
Crack which lines? I've been planning on finding a dirt/gravel road to trigger the ABS.
Originally Posted by Berty_K
My problem isn't with the travel, it's the spongyness, and the fact that I'm not getting the same results from the "40 pedal press" procedure that other people reported. But like I said, I might be overthinking this. The brakes seem to work, but I'm a little worried that there's a problem with my master cylinder (minor leak?) that the brake booster is covering up.
