Old 08-05-2024, 04:36 PM #1
WillCall08's Avatar
WillCall08 WillCall08 is offline
WillCall08 is on a distinguished road
WillCall08's Avatar
Question Definitive brake kit recommendations.
I have an 08 V6 Limited and am in the market for new brakes. The front likely needs new pads/rotors and the rear got replaced recently by a small shop but the brake dust in general front/rear has me wanting to at least replace the rear pads as well as the front with a ceramic variant. Can anyone tell me what I should get and send links to all products so I can just go ahead and order them, and if I really should replace the rear rotors even though they aren’t that old because I want to change the pads to ceramic let me know what I should do for the front and rear. Thanks in advance
WillCall08 is offline   Reply With QuoteReply With Quote
Old 08-06-2024, 12:48 PM #2
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
Go with rockauto.
Akebono PROact pads (same as OEM).
Centric rotors- cheapest rotors are fine unless you need the coated rotors for rust protection.
Calipers will have a stamp (WH or WG) that will tell you what size rotor to buy.
'08 Silver SR5 V6 4x4: OEM+
Berty_K is offline   Reply With QuoteReply With Quote
Old 08-06-2024, 01:40 PM #3
Buckaroo's Avatar
Buckaroo Buckaroo is offline
Buckaroo will become famous soon enough Buckaroo will become famous soon enough
Buckaroo's Avatar
About 4 years ago I started installing Powerstop ceramic pads and Geomet coated rotors on all my vehicles. Typically buy from Rockauto but always double check the price on Amazon. You can buy them in a kit but surprisingly it can be cheaper to buy them individually. For my T4R, I installed the Z17 pads. If you do a lot of towing, you could consider the Z36 pads. Regarding front rotors, you should verify whether you need the 338mm size or the smaller 319mm's.
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
Buckaroo is offline   Reply With QuoteReply With Quote
brake , front , pads , rear , replace
Brake and control arm recommendations boostedka 4th Gen T4Rs 5 06-10-2021 06:10 PM
Brake Upgrade Recommendations DC1843 3rd gen T4Rs 23 04-01-2015 07:16 PM
Any recommendations for brake pads? Hulley 4th Gen T4Rs 4 08-11-2011 02:35 PM
Definitive answer on the charge/brake light issue KidVermicious Classic T4Rs 6 03-01-2011 12:44 AM
Brake pad brand recommendations el_chapu-bling 3rd gen T4Rs 32 11-17-2006 03:26 PM
