Old 08-11-2024, 11:32 AM #1
Bolderboulder's Avatar
Bolderboulder Bolderboulder is offline
Bolderboulder is on a distinguished road
'05 SR5 - Front and rear washer fluid will not spray
2005 SR5 - 181,000 miles
Both front and rear washer fluid will not spray now, both quit at the same time. The reservoir is full and spray nozzles are not clogged. Does the '05 have a separate pump for the front and rear? I know the front pump is located at the bottom of the reservoir and the right front wheel well cover must be detached to access it.
If there is a pump for the rear, where is it located? And is it the same part number as for the front?
Thanks!
Bolderboulder is offline   Reply With QuoteReply With Quote
Old 08-11-2024, 01:33 PM #2
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Washer Fluid Not Working
Windshield Washer Pump Not Working
Windshield-washer fluid pump problem
'07 both windshield washer pumps not working
Windshield washer pump is hummin but no ouput
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
front , located , pump , rear , spray
Washer spray nozzles Francis 3rd gen T4Rs 81 12-31-2022 11:58 AM
Rear window washer fluid 4Funnr 5th gen T4Rs 27 06-11-2021 12:11 PM
Rear windshield washer fluid? arehman11 5th gen T4Rs 18 01-23-2018 03:29 AM
2000 4Runner Rear washer fluid line BROKEN needs repair skolinsk 3rd gen T4Rs 16 12-13-2017 05:44 PM
Front/rear differential fluid, trans fluid and transfer case fluid change 88 Kel Varnsen Classic T4Rs 1 05-20-2012 03:26 AM
