Old 09-06-2024, 08:33 AM #1
grumpy02 grumpy02 is offline
Real Name: Stan
grumpy02 is on a distinguished road
Real Name: Stan
"Programmable Things" in my 4th Gen?
Does anyone have a list of things that can be "programmed" by a dealership in a 4th gen? Or know where such a list is posted? Things like "beep" when locking/unlocking, default setting for the fresh/recirc on the HVAC. I want to have those two set & possibly a key programmed. I assume the dealer will charge a minimum of 1 hour shop time so I want to compile a list of what I want done so I can get it all done at once. As always TIA.
grumpy02 is offline   Reply With QuoteReply With Quote
Old 09-06-2024, 09:45 AM #2
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb is a jewel in the rough ArthurKotb is a jewel in the rough ArthurKotb is a jewel in the rough
ArthurKotb's Avatar
Real Name: Rich
I don't know about the beep but your owner's manual tells you how to change the door lock settings. I changed mine to unlock all the doors when I put it in park, lock them when I put it in gear. There are a few choices.
I don't have the dual HVAC so I can't speak to any default settings there. I know mine will go to recirculate for the A/C if you set the temp to LO. I've not checked the owner's manual for that.
You need a locksmith to change/code the engine immobilizer code. They can do it cheaper than the dealership and they will come to your home or work. You can change the key fob but those instructions are usually part of a new key fob. I'm attaching the instructions I used for mine, maybe it will work for you.
File Type: pdf 2004 Toyota 4Runner Remote Programming.pdf (93.9 KB, 72 views)
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 09-06-2024, 04:37 PM #3
Moist's Avatar
Moist Moist is offline
Moist is on a distinguished road
Moist's Avatar
Automatic windows/moonroof.
Only with technicality, when you disconnect the battery the automatic windows must be reprogrammed in order to work. This is how you disable them if you don't like them.
This also means you must re-program rear window in order to use rear wiper.
Moist is offline   Reply With QuoteReply With Quote
Old 09-06-2024, 10:37 PM #4
shine shine is offline
shine is on a distinguished road
You can program everything that the dealer can with a cable like this one https://www.amazon.com/gp/product/B084P3WCJC and a pirated copy of Techstream. You'll probably need to spend some quality time with google to get a version of Techstream, an older version will be fine as long as it is not older than your 4Runner
shine is offline   Reply With QuoteReply With Quote
4th , gen , list , programmed , things
**San diego** 4th gen ICON "stage 1" suspension 2.5"Coilovers,2.0" rear shocks,2"spri Anteupp For Sale: T4R Items 0 02-05-2024 01:26 PM
Things Toyota needs to "fix" on the 6th Gen 4Runner MidnightOffRoad 5th gen T4Rs 78 06-28-2018 09:31 PM
How much "abuse" can these things take? Macaque 4th Gen T4Rs 5 07-14-2012 04:15 PM
Things that go "bump" in the night! mikeandpat Maintenance/Detailing 7 10-16-2010 01:35 PM
Zero point didnt work how to turn off "VSC TRAC" & "VSC OFF" & "ABS" lights sciff5 4th Gen T4Rs 6 09-27-2010 12:10 AM
