Old 10-05-2024, 03:43 PM #1
m85476585 m85476585 is offline
Real Name: Matt
m85476585 will become famous soon enough
Real Name: Matt
Rumbling Noise in Reverse
I just finished some maintenance on my dad's 4Runner (2007 V8), and I noticed a rumbling noise that was never there before. It happens in reverse around 600-700 RPM. The noise is there whether I'm stopped or rolling, on or off the brakes. It doesn't do it in Drive, Park, or Neutral, only in reverse. The noise seems to be coming from the engine bay. The engine was mostly warmed up when I figured out how to reproduce the problem, but it happened a few times before that.
Here's a video: https://youtu.be/c6WjO_c9-1k
I don't think any of the recent maintenance is related. I changed CV axles, replaced the front differential fluid, replaced the coolant, bled the front brakes, replaced the rear brake pads and rotors.
It has RCI aluminum skid plates on the engine and transmission, so there's a slight chance one of them is vibrating, but the bolts are tight.
Any ideas what could be causing this noise?
2007 V8 Limited 4WD
m85476585 is offline   Reply With QuoteReply With Quote
Old 10-06-2024, 02:05 PM #2
Real Name: Matt
Real Name: Matt
It turns out it was the skid plates. The catalytic converter guard was just barely rubbing on an exhaust heat shield in one spot. A quick trim with the reciprocating saw made clearance. In addition, the plastic spacers at the back of the engine skid had fallen out, and there was a pebble trapped between the frame and the engine skid.
2007 V8 Limited 4WD
engine , noise , replaced , reverse , rumbling
Noise when in reverse BTO 3rd gen T4Rs 2 09-04-2024 06:03 PM
Noise while stuck in reverse SteinRunner 3rd gen T4Rs 2 06-29-2017 09:00 PM
Horrible rumbling and noise out of the rear end SpacecraftRunner Classic T4Rs 4 06-17-2011 10:44 PM
transmission noise - was noise in reverse jmfranc 3rd gen T4Rs 2 07-07-2008 08:10 AM
