Originally Posted by FrontRange4
Hey man! I had this issue. Your planetary gear within the steering rack is skipping a tooth. I assume that you can have your truck on and in drive, turn the steering wheel slowly counter-clockwise and youll either hear or feel a pop and now the steering wheel will be back on the correct spot.
You will need to get this fixed. It can skip the other way as well and can be a safety issue.
Is this a common problem? My 2WD/RWD truck pulls to the left/needs correction to the right. At the last MOT (Inspection) all they flagged up was anti roll bar drop links had perished rubbers, so I have ordered those, but they couldn't say if that was the problem. Everything else would have been checked.
I had tracking/alignment done somewhere else and they said it was fine but I didn't get a print out of results.
The only other thing I noticed was that on a section of the M25 (Highway) where the road surface is concrete pads rather than tarmac, is that the regular "oscillation" type input from the road surface made the steering feel slightly squirrely, but it's always been a horrible road surface to drive on in any vehicle.
