Old 11-16-2024, 10:35 PM #16
RESP1's Avatar
RESP1 RESP1 is offline
RESP1 is on a distinguished road
RESP1's Avatar
Shake n' Brake
Likely Culprits (in order of probability):
* Warped Brake Rotors: This is the most common cause of steering wheel shake when braking, especially at higher speeds.
* Why it fits: Downhill braking generates more heat, which can warp rotors over time. The shaking at low speeds on uneven surfaces might indicate uneven rotor wear or deposits.
* What to check: Visually inspect the rotors for any signs of warping (uneven surface, blueish discoloration). Measure rotor thickness and runout (wobble) with a dial indicator.
* Sticking Brake Caliper: A caliper that doesn't release fully can cause uneven braking and shaking.
* Why it fits: Might explain the low-speed shake if the caliper is dragging slightly.
* What to check: After driving, carefully feel the temperature of each wheel hub. A significantly hotter one suggests a sticking caliper.
* Suspension Components: While you've upgraded some parts, worn bushings or ball joints can introduce play and contribute to shaking.
* Why it fits: Loose components can amplify vibrations, especially on uneven surfaces.
* What to check: Have a mechanic inspect for any excessive movement in control arm bushings, ball joints, and tie rod ends.
* Wheel Bearings: A worn wheel bearing can cause vibration and shaking, sometimes more noticeable during braking.
* Why it fits: Less likely given no vibration at speed without braking, but still worth considering at 250K miles.
* What to check: Jack up the front end and check for play in the wheels by grabbing them at 12 and 6 o'clock and trying to rock them. Also, listen for any grinding or rumbling noise when spinning the wheels.
Less Likely (but still possible):
* Tires: While you've rotated and balanced them, there's a slight chance of a tire issue, especially given the low-speed shake. Check for uneven wear or any bulges/damage.
* Steering Rack: Problems here usually cause more consistent issues, but wear can contribute to shaking in some cases.
Where to Start:
* Thorough Brake Inspection: Start with the most likely cause – the brakes. Have the rotors inspected and measured. If they're warped or excessively worn, have them resurfaced or replaced (along with new pads).
* Caliper Check: While inspecting the brakes, check the calipers for proper movement and signs of sticking.
Important Notes:
* Don't automatically assume warped rotors! While common, it's crucial to rule out other issues.
RESP1 is offline   Reply With QuoteReply With Quote
braking , speed , steering , vehicle , wheel
(HELP) 2014 SR5 steering wheel shake from braking over 50mph and dropped 2mpg? YNPCA General Discussions 6 02-17-2021 07:48 AM
Wheel Shake when braking JMG73072 5th gen T4Rs 36 09-21-2015 03:41 PM
Steering Wheel Shake when Braking MonicaColvin Problems & Warranty Issues 1 05-08-2015 03:41 AM
2004 Limited v8 4WD wheel pull and shake while braking ccvortex Problems & Warranty Issues 0 05-08-2014 03:02 PM
Help diagnose a shake / vibration at 72-77 mph 2002_thundercloud 3rd gen T4Rs 2 06-01-2011 04:54 PM
