10-28-2024, 01:28 PM
Help diagnose my front end shake on braking.
I've looked at numerous past threads on this issue, but there's very little that's definitive from people who have actually fixed the problem themselves. A lot of opinions on what causes it.
Any help before I invest serious dollars.
The problem: When braking at highway speed, shimmy from front end which shakes the steering wheel back and forth. Most noticeable when going downhill (50 – 70 mph or so) and applying light to moderate braking to reduce speed. Does not pull to either side. Steering wheel shales fairly violently (enough that its a little scary), but the vehicle doesn't really shake.
Notably, a very similar steering wheel shake at low speed (5 mph or less) on dirt with minor bumps/washboards. Wheel shakes more than would be expected form the road conditions.
Tires recently roteted and balanced. Vehicle tracks straight on pavement. No vibration at any speed when not braking. Vehicle has 250K miles, Dobinson's suspension and new LCAs installed a couple of years ago. Front brakes done and left caliper replaced about 30K ago.
Brakes? Suspension? Steering? Where to start? I recognize that this may become a series of fixes.
10-28-2024, 02:14 PM
If you haven't replaced your rotors when you did the front brakes, start there. I would stick with OEM or brembo blanks.
2007 4runner Sport V6 4wd: 275/65r18 Maxxis Razr AT - Eibach/TRD lift - Cali Raised sliders
10-28-2024, 03:48 PM
There is an interesting app called Smoothride Pro by Pro-Cut that might give you some information. It helps distinguish between rotor thickiness variation (i.e. warped rotors) and wheel balance issues. Have used it and found it to be pretty accurate. Good to use it to get a baseline before you have issues but suggest you give it a go. Kind of sounds like rotor related issue. If you replace them, clean the hub well and verify rotor run-out in spec with a dial indicator.
Smoothride PRO | Pro-Cut On Car Brake Lathes
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
10-28-2024, 05:14 PM
Originally Posted by Texmax
Worn parts. Replace anything worn.
Anything in particular? At 20 years and a quarter million miles there’s a lot of worn parts…
10-28-2024, 06:31 PM
Have you checked for frozen calipers? These 4th Gens eat stock or auto zone type. I went with Powerstops my last round and haven’t looked back.
Also, could be a hub going bad.. Around 200K the average on them. If you do one, do both.. But these normally make noise when going bad.
Black 2003 Sport, V8, 4WD, 229K miles - as of October
2024, AMSOIL lubed, JVC Headunit 925BT, Rockford Fosgate Amp, Rockford Fosgate 10'' P2's in custom box
10-29-2024, 09:01 AM
I had a mild wiggle on braking, with zero noticeable play when I jacked it up and shook the wheel/tire. I'd also replaced all bushings + ball joints + the shock + pads/rotors/calipers in the last 5k or so to help improve the ride and that brake issue persisted.
Finally replaced both front hubs and ta-daa, the issue was gone immediately and the bearings were definitely crusty and slightly corroded when I got them out to look. Given the age/mileage mentioned here I'd be checking tie rods, and strongly considering either pulling a hub to check or just replacing them for the hell of it.
10-29-2024, 07:45 PM
Classic cause is rotor problems. Usually by switching brands of pads and not turning rotors to get old pad material off. You could have an pad material uneven buildup on your rotors -often called warped rotors.
Also bed-in your pads on refinished rotors to apply an even coating of pad material onto rotors.
My 2 cents.
10-30-2024, 04:16 PM
Also had a similar issue at very similar conditions to yours (shimmy when braking at speed).
Turned out my upper control arm (JBAs) ball joints and bushings were worn. I could feel a bit of play through the steering knuckle.
Replaced both and things felt tight again.
'08 Silver SR5 V6 4x4: OEM+
11-05-2024, 12:47 PM
My vote goes to a sticking front caliper piston/uneven inside/outside rotor wear. Also, torque the wheel nuts by hand with a torque wrench set to 83 ft.-lbs.
'94 Pickup Xtra-Cab V6/Auto 4WD
'09 4Runner SR5 V6 4WD
'21 Tacoma TRD Off-Road
11-11-2024, 03:58 AM
Real Name: Carlos V.
Same symptoms. Sticky calipers. Powerstops solve it
Gold 2003 4Runner SR5 V6 2WD A340E
Grabber A/T, Brembo rot, Akebono pads, Optima batt, HKB Volt. booster, Buffalo Bayou recovery
Sony XAV1000, LED interior and reverse, Weathertech, Flux-Turbocharged tire valve caps.
11-11-2024, 02:33 PM
Real Name: Reinout
Real Name: Reinout
This sounds like warped brake rotors: you can take them to an auto shop and have them measure the run-out and potentially face them.
Or you can buy new rotors.
1997 4Runner SR5- ~376k Miles and counting
2007 4Runner Limited V6- 175k Miles
2011 VW JSW TDI- 150k Miles
2006 Scamp trailer 16'
11-13-2024, 12:14 PM
Real Name: William
Real Name: William
I had a similar issue, rotors are worn most likely and I would check for a seized caliper as well. Power stop makes a great replacement caliper.
_________________________________________________
2005 4Runner Sport V6 4X4 Stratosphere Mica
33in BFG KO3s, ModCo M72 Machined, 3/1in Dobinsons Long-Travel IMS Lift, No Swaybars, TNF Recovery Points,
11-14-2024, 08:31 PM
I had a powerstop caliper seize up after only 2 years. The red is real pretty but I learned my lesson... only OEM for me if available.
11-14-2024, 08:43 PM
I put brand new OEM calipers from the dealer two years ago. A month ago, I opened the bleeder screws, pushed the pistons back in fully to purge the fluid in the calipers from the bleeder screws. Then I flushed the front lines while topping up the master cylinder. It's but one way to get more life from a set of calipers.
11-16-2024, 12:53 PM
Good tip. Probably unwarranted but I just didn't trust them after they seized up.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
