Old 11-20-2024, 03:52 PM #16
alia176 alia176 is offline
alia176 has a spectacular aura about alia176 has a spectacular aura about
Originally Posted by Az4runnin View Post
Mine says NTN 6203 LH. Belt Tensioner Bearing
NTN 6203LH, RadialDeep Groove Ball Brg 17 Mm Id X 40 Mm Od X 12 Mm W Double Sealed.
Just ordered a New bearing through Grainger. Same NTN One Thanks for the info @alia176
Just for reference
NSK BD20-15DUL Japan
Idler Pulley Bearing
Excellent, glad you found a quality replacement. I can't recall what kind of a snap ring plier you need for this project but it's easy to swap out the bearing.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 12-23-2024, 02:04 AM #17
Az4runnin's Avatar
Az4runnin Az4runnin is offline
Az4runnin will become famous soon enough Az4runnin will become famous soon enough
Az4runnin's Avatar
Job is done. Old Bearing came out with some PB Blaster a 24mm socket and a hammer. Came out pretty easy. I put the Pulley in the Oven for about 30 minutes and the Bearing in the freezer for a few hours. Took the pulley out of the oven, took the bearing out of the freezer put the bearing in the pulley. It went about 2/3 of the way in.. then I took the old bearing, put it on top of the new one and tapped it the rest of the way in with a hammer slid right in no problem. Pulley is on the truck with a brand new belt.
4.7  V8 Water pump going Bad or Worse-img_7547-jpg  4.7  V8 Water pump going Bad or Worse-img_7576-jpg
2003 V8 Limited 4x4 Black. JBA UCA's, TRD Pro Wheels. OEM LED Tails, 2012 FJ Springs F/R 5100's F/R 1.75 Cooper AT3 4S 265-70-17. Bye X Reas, Wet Okole Seat Covers Weathertech liners.
Az4runnin is offline   Reply With QuoteReply With Quote
Old 12-24-2024, 12:45 PM #18
awesome sauce, nice job amigo. You saved some coin AND used a quality bearing, not a cheap POS from Amazon.
belt , miles , pump , sound , started
Slight water leak.. water pump or??? LargeOrangeFont 4th Gen T4Rs 6 08-26-2019 06:52 AM
Leak from water inlet/water pump joint - V8 GLP 4th Gen T4Rs 5 01-12-2017 10:52 PM
Engine whine - oil/water pump, or worse? climberbry 4th Gen T4Rs 10 07-29-2014 12:03 PM
Help! New timing belt, water pump, and spark plugs = higher water temps??? vthokie 3rd gen T4Rs 15 05-16-2011 10:59 PM
water pump superooster Classic T4Rs 3 02-11-2010 07:14 PM
