Old 11-12-2024, 01:44 PM #1
4R005 4R005 is offline
4R005 is on a distinguished road
DTC P0420 - Cat system efficiency
Two weeks ago ( Nov 1 ), the Check Engine and VSC cluster of lights came on for my '05 4R LTD V8. Scan tool indicated catalyst (first one from exhaust manifold) in Bank 1 efficiency "Low", hence DTC P0420. Up and downstream O2 sensors read "OK".
Back in mid Sept this year, the alternator crapped out about 4 miles from home and Limp Mode came on. Made it back to house at a crawl pace with frequent "minor explosions" ( ? ) from the exhaust system. At that time I thought those ME's were from excess gas igniting in the cats as I had the throttle pegged to the floor to get it moving at the crawl pace speed.
My questions:
1. Is the present DTC a result of this excess fuel dirtying the cat's media and is there a cure ( e.g. a bottle of cleaning fluid ) that will resuscitate the cat. If so, please provide suggest product data. Or, I'm SOL and cat replacement is the only solution.
2. Will operating the vehicle w/the DTC do permanent damage. Vehicle is use only for short ( 10 miles) round trips into town for groceries.
Any recommendations, advice or real life experiences are welcome
4R005 is offline   Reply With QuoteReply With Quote
Old 11-12-2024, 03:39 PM #2
Cezar Cezar is offline
Cezar is on a distinguished road
If it's the downstream sensor (hard to tell from your post) then it has absolutely no control over fuel economy, emissions, or engine safety. Their only purpose is to throw a CEL when the system thinks the cats are not operating fully. The upstream sensors actually matter because they're what controls air/fuel ratios.
I just put an o2 sensor spacer on my downstream sensors when I had this issue but depending on emissions inspections in your area that may or may not be a viable option.
Sounds like your alternator crapping out caused the coils to misfire and raw gas dumped into the exhaust which can be bad for cats. I think short trips as well if they're never getting up in temp to fire off. My wood stove has catalytic convertors and it's very important to keep your temps up or they can be harmed.
Cezar is offline   Reply With QuoteReply With Quote
Old 11-13-2024, 08:05 AM #3
Buckaroo's Avatar
Buckaroo Buckaroo is offline
Buckaroo will become famous soon enough Buckaroo will become famous soon enough
Buckaroo's Avatar
My questions:
Continuing misfires associated with unburned fuel definitely kill cats so maybe your severe, short duration experience could have done it in. I am doubtful that cat cleaning snake oil does any long term good but people try it when they have to pass emissions testing. No problem continuing to drive with a bad cat. Also, I don't believe the downstream O2 sensor controls anything - it just serves to detect a malfunctioning cat and lighting your CEL.
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
Buckaroo is offline   Reply With QuoteReply With Quote
Old 11-13-2024, 09:20 AM #4
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I would take it on a long highway drive, about an hours worth and see if that "self cleans" the cat. As stated, cats like to be hot to function at their best.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 11-13-2024, 10:09 AM #5
Much thanks to all with your inputs, really appreciated and did lessen my stress level to use the vehicle or drive it for any distance.
For the record, I did replace the downstream O2 sensor after getting the DTC. The upstream O2 sensor on this bank ( # 1 ) was replaced 15k miles ago. Other than the lights being on in the dash, the 4R runs great as before. Now knowing that engine will not suffer any lasting damage from a bad cat, I'm going to take a few long drives as suggested to heat up the cat(s) and hopefully that will be the cure.
Luckily, I do not have any annual emmission checks to worry about here in Ontario.
Thanks again for all the help.
Old 01-07-2025, 08:09 PM #6
Hi everyone,
here's the update to my DTC P0420 problem.
I searched the web for O2 sensor extenders ( also called spark plug extenders ) and had more positive user results than negative. Also came across some who had dump a bottle of Seafoam into a full tank of gas and again with mixed results ( best case from the Seafoam additive was lights went off for 2 years but came back ). Decided to try the O2 extenders ( @Cezar . Thanks ) and installed a 90 degree extender to the downstream sensor. Almost two months now and the lights have not returned. For good measure I threw a full can of Seafoam when tank was at the half full mark. Fingers & toes crossed.
Thanks again everyone.
Old 01-08-2025, 03:53 PM #7
Zero0575's Avatar
Zero0575 Zero0575 is offline
Real Name: Casey
Zero0575 will become famous soon enough Zero0575 will become famous soon enough
Zero0575's Avatar
Real Name: Casey
Can vouch for the o2 extenders working. I have them on mine to get rid of p0420 and p0430 after installing my headers. Have also used them on other cars for cat efficiency codes. They work.
2007 Limited V8 | 275/70/18 Falken Wildpeak AT3W | Spidertrax | 4xInnovations Weld On Sliders | Victory 4x4 Blitz Front Bumper | RCI Skids | TNF Rear Bumper | Smittybuilt Winch | KOYORAD Aluminum Radiator |OME 886 Front/Toytec Superflex HD Rear and OME Shocks/Struts | JBA High Caster UCA | Rebuilt LCA with Superpro bushings + Moog BJ | Apex Kwik Linx | HCF Delete | Doug Thorley Shorty Headers | Magnaflow HFC | Gibson Catback | Rear Diff Breather Extension | 20" Spot/Flood | 6" RSE Spots | DD SS3 Yellow Fogs | Amber Grill Lights | Fog Lights Anytime Mod | TPMS Bypass
Zero0575 is offline   Reply With QuoteReply With Quote
cat , crawl , dtc , exhaust , vehicle
Cheap potential P0420 P0430 Catalyic Converter Efficiency Fix Warwicke36 4th Gen T4Rs 26 05-14-2020 10:37 PM
Video - Tackling The Dreaded P0420 (Catalyst Efficiency Below Threshold) shadow247 3rd gen T4Rs 2 03-27-2014 10:54 AM
Catalyst system efficiency below threshold bank 1 dunebashing toyota 3rd gen T4Rs 3 08-17-2012 02:57 PM
P0420 - Replaced A/F after P1130/1135 a few months ago... now P0420 low ?? Bank 1 Headly 3rd gen T4Rs 19 01-23-2011 08:52 PM
